Go built or go home right? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-02-2012, 06:57 AM Thread Starter
Ok guys thinking about picking up a spare 7.3 engine and trans to build and put into my truck when finished. Was wondering what would be good internals to go with I'm doing Carillo rods. So what should I do for pistons and such like that? Including head work. I've got the trans already taken care of. Goin for big numbers so what would be good internals to go with from pistons to injectors to everything in between
Tylers7.3 is offline
post #2 of 14 (permalink) Old 12-02-2012, 07:22 AM
OSCS's Avatar
Re: Go built or go home right?
You need to be more specific as to what your goals are
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #3 of 14 (permalink) Old 12-02-2012, 07:38 AM Thread Starter
800 rwhp + want something balls to the walls built
post #4 of 14 (permalink) Old 12-02-2012, 10:23 AM
the stryker god
Just call swamps.
bruce51d is offline
post #5 of 14 (permalink) Old 12-02-2012, 04:22 PM
OSCS's Avatar
If your actually serious and have the money to do it (at least 25 grand) your on the wrong web site. Visit powerstrokearmy and do ALOT of reading first.
OSCS is offline
post #6 of 14 (permalink) Old 12-03-2012, 01:06 AM
biggin2001's Avatar
What are you Going to use the truck for? Dd or play toy?
biggin2001 is offline
post #7 of 14 (permalink) Old 12-03-2012, 08:40 PM
Village Idiot
southmike's Avatar
i would do hyprmax rods instead of the Carillo rods..
that wont be what lets loose first.
but yes you will need a big wallet..some of the big shops can help you get there or close.
800 is do-able but usually involves spray. hp is hp.
girdle, or bed plate, main studs, coated mahle pistons, hypermax (rods, valves and pushrods, and springs), h11 studs, custom cam from gearhead maybe, some 3k worth of machine work on the heads. big oil, some serious sticks, an ati damper or fluidamper, melling oil pump, di headers, compounds , and a bts .
you might be close after a ton of custom tunes and dyno time. and two stages of nos.\
ooor call blowby up and ask if he wants to sell his engine...lol
southmike is offline
post #8 of 14 (permalink) Old 12-05-2012, 11:01 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Dedicated tow rig?
Stock
PowerstrokeJunkie is offline
post #9 of 14 (permalink) Old 12-06-2012, 01:01 AM
Black 02's Avatar
Originally Posted by PowerstrokeJunkie View Post
Dedicated tow rig?
Call David Lott at Diesel Innovations or Swamps.
Ryan
2002 Black F-350 4x4 Crew Cab LB Lariat
DP-Tuner F6, Irate T4, S468, T-500, 910's, AFE Intake, MBRP Stainless 4" Exhaust, Riffraff OCR, Casserly Stage II's, Riffraff FRx, Rebuilt 4R100 w/ Suncoast Triple Disc Converter, 6.0L Trans Cooler. 37x12.50R16.5 Super Swamper Trxus MT's w/ 6" Icon Lift. Locker Front & Rear w/ Heavy Duty Warn Hubs
Black 02 is offline
post #10 of 14 (permalink) Old 12-06-2012, 02:38 AM
biggin2001's Avatar
Is love to see how that would pan out, 800 horse towing a skid loader and hitting the spray!! I'm sire you wouldnt scatter that motor or nothin!
