avout to do injectors, anything else while im there? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 11-29-2012, 10:12 AM Thread Starter
richh789's Avatar
I have a hard working 00 with 230k. I think its time for inj. Going with swamps single shot stage one. Looking for mild increase in hp, but also mpg.
Is there anything else that should be changed while i have it appart? It has new uvc harness and glow plugs already.
00 F350 cclb former dually
1"shackles, 6" lift, 37" oz, HD headlights, AFE intake, bellowed up pipes,swamps stage 1s, swamps tunes, 5" exhaust, iah, ebpv, foil all deleted,zoodad, pillar guages; boost, Pyro, fuel pressure. MBC,
97 ex cab PS SOLD
04 CCLB 6.0 EDGE J W/A, 4"mbrp Sold
93 idi sold
richh789 is offline
post #2 of 21 (permalink) Old 11-29-2012, 12:24 PM
OSCS's Avatar
Re: avout to do injectors, anything else while im there?
I'd probably do the valve seals but that is going to be some extra work
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #3 of 21 (permalink) Old 11-29-2012, 12:51 PM
What about checking all of the bolts for correct torque. I read on a site that when you do the ucvh it is wise to check everything while in there. Sometimes the bolts work loose a little over time and re torquing them will also quiet the motor noise a little. Follow specs on in/lbs. Dont break anything :-)
kenmore is offline
post #4 of 21 (permalink) Old 11-29-2012, 01:19 PM
dieselman81's Avatar
Send a message via Yahoo to dieselman81
Injector cups... Your gonna have to run custom tunes for your truck to run right after swapping injectors if you are going to a single shot injection
2002 F350 4x4 7.3 CCLB- Stock
dieselman81 is offline
post #5 of 21 (permalink) Old 11-29-2012, 01:32 PM
whistle tits
ghohouston's Avatar
Do not change your injector cups if theres no reason to...
ghohouston is offline
post #6 of 21 (permalink) Old 11-29-2012, 01:38 PM
Seems silly not to since he's gonna be in there... especially with high mileage
post #7 of 21 (permalink) Old 11-29-2012, 02:04 PM
Village Idiot
southmike's Avatar
Have a look at toms post on coating the valve covers...if sound bothers you.
Otherwise button it up change the oil and tunes and enjoy...
southmike is offline
post #8 of 21 (permalink) Old 11-29-2012, 02:10 PM
whistle tits
ghohouston's Avatar
I have NEVER seen anyone replace cups for no reason, thatd like hey, your head gaskets are old, replace them, even though they're perfectly and aren't that prone to fail
post #9 of 21 (permalink) Old 11-29-2012, 02:14 PM
cups are prone to fail tho
post #10 of 21 (permalink) Old 11-29-2012, 03:24 PM
whistle tits
ghohouston's Avatar
Do they fail, sure, do they fail often enough to be replaced while doing injectors, im sorry, I am gonna disagree and say no
