Need some help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-28-2012, 10:20 PM Thread Starter
smokin_fast's Avatar
Cool Need some help!
Hey! I've got a 2001 excursion 7.3 here with CAI and bully dog tuner and having some problems with it... first off was driving the other day and lost all but like 2psi of boost.. finally got around to fixing it today and (after many hours) found that the ebpv rod clip had come loose and fallen off.. so ebpv was stuck close! haha! so fixed that went to take it for a drive and hit 42psi of boost at 3/4 throttle!! (wth) but it stays at like 25 psi in the (stock) setting, but overboosts in any of the power settings on the bully dog,, so im wondering what you guys think could be wrong??? thinking it might be like the wastegate control module? or something??
Also does any know how to connect the bully dog tuner to the pc so i can update it, when i plug it into the pc nothing happens??
Thanks for the help guys!
smokin_fast is offline
post #2 of 13 (permalink) Old 11-29-2012, 02:32 PM Thread Starter
Re: Need some help!
No one? Not even on the bully dog part?
post #3 of 13 (permalink) Old 11-29-2012, 02:51 PM
the stryker god
Re: Need some help!
I think your gauge is wrong. Throw that bullydog away and get some decent tunes
bruce51d is offline
post #4 of 13 (permalink) Old 11-29-2012, 05:16 PM Thread Starter
Re: Need some help!
Its boosting more I can hear it.. so no the gauge isn't wrong.. also can't get rid of it, not my truck..
post #5 of 13 (permalink) Old 11-29-2012, 05:21 PM
the stryker god
Re: Need some help!
Stock injectors aint gonna make 42 pounds of boost so i think it is the gauge
bruce51d is offline
post #6 of 13 (permalink) Old 11-29-2012, 05:49 PM Thread Starter
Re: Need some help!
So why would it just almost double all of a sudden? And the turbo doesn't sound the same as before...
post #7 of 13 (permalink) Old 11-29-2012, 06:03 PM
the stryker god
Re: Need some help!
If the ebpv was shut and you opened it up its gonna sound different
bruce51d is offline
post #8 of 13 (permalink) Old 11-29-2012, 06:07 PM
jdeiss
Re: Need some help!
go buy a cheap gauge from napa or where ever that goes to 30psi mechanical one and see what it says. even if you get a 20psi and see how far it goes on the gauge. my buddy could spin his all the way back to the 0psi then the spring broke but it would give you a idea
96 stroker 370k and counting SCLB,xlt, zf5.4.10s
6637 filter,140V IDM,ts chip,3" diamond eye dp 5" back 7in tip
glow sh*t gauges---SOLD
96strok is offline
post #9 of 13 (permalink) Old 11-29-2012, 06:16 PM Thread Starter
Re: Need some help!
That's what I was thinking about doing... but also the turbo doesn't sound the same.. its quite a bit louder and different sounding... also im pretty sure theirs more power there then its ever had.. (but maybe that's just me)
post #10 of 13 (permalink) Old 11-29-2012, 06:20 PM
the stryker god
Re: Need some help!
If the ebpv was closed then its gonna make more power and sound different
bruce51d is offline
