Newbie - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 11-27-2012, 08:36 PM Thread Starter
HPSETWR
Newbie
Alright I am thinking about getting a 7.3 and I would like to get some more power out of it this what I am thinking. this will be used for towing under 13k at the most and plowing.
-DP tuner with custom tunes
-Flo-Pro T409 turbo back W/ muffler delete
-AFE stage 2 pro dry7 cold air intake
-Air Dog 100
-Fuel mods that Powerstokehelp shows
-Garrett GTP38R with batmowheel upgrade (if thats possible)
-Superchips dpi (maybe)
-The waste gate and boost fooler set at 40 PSI
-Leveling kit and some 33's
Will the stock head bolts and tranny handle these mods or will I need to upgrade some parts like the shafts, flex plate and torque convertor.
brads18 is offline
post #2 of 20 (permalink) Old 11-27-2012, 08:55 PM
Re: Newbie
-Air Dog 100Junk
-Fuel mods that Powerstokehelp shows That guy is retarded
-Garrett GTP38R with batmowheel upgrade (if thats possible)Skip the batmojunk
-Superchips dpi (maybe) Prolly junk as well
Yes the stock trans will handle it but its a goo idea to add a 6.0 trans cooler, modded valve body and a good triple disk TC.
BTW my other answers are in red.
countryboyrob is offline
post #3 of 20 (permalink) Old 11-27-2012, 09:28 PM Thread Starter
HPSETWR
Re: Newbie
Thanks bud
I am thinking about slapping some swamps 175/30% with a adreniline hpop later on if I can afford it.
Will I need head studs and a bult tranny then
with the air dog are they just a waste of money becasue they have no benefit.
brads18 is offline
post #4 of 20 (permalink) Old 11-27-2012, 09:37 PM
Re: Newbie
No you want need to do headstuds or a built trans..... And the airdog is a waste of money, do a regulated return and be done.
Also before buying another HPOP hook a scanner to your truck first and watch live data of the hpo psi and duty cycle.
post #5 of 20 (permalink) Old 11-27-2012, 09:47 PM Thread Starter
HPSETWR
Re: Newbie
Should I be safer than sorry and upgrade the the input shaft and flexplate to heavy duty billet ones
will the pmr rods handle these mods
brads18 is offline
post #6 of 20 (permalink) Old 11-27-2012, 09:54 PM
Re: Newbie
No to both and do you know if you have pmrs?
post #7 of 20 (permalink) Old 11-27-2012, 10:03 PM Thread Starter
HPSETWR
Re: Newbie
Right now I am just trying to gather technical info I do not have a truck yet just trying to figure out cost and if its worth it. one truck is a 2003 and has them the other is a 2002 and I am not sure it was hard to read the serial number on the block assuming from the production date it does not from my research. I like to have all the info in hand before I spend the money on a new truck.
brads18 is offline
post #8 of 20 (permalink) Old 11-27-2012, 10:12 PM
Re: Newbie
And yes, pmrs will be fine with those mods...
post #9 of 20 (permalink) Old 11-27-2012, 10:16 PM Thread Starter
HPSETWR
Re: Newbie
Thanks bud
this shows how much I don't know and how cocky I am lol all has to do with age
brads18 is offline
post #10 of 20 (permalink) Old 11-27-2012, 10:31 PM Thread Starter
HPSETWR
Re: Newbie
Would I be better off having a diesel shop do the work then doing it myself with assitance from a diesel tech.
brads18 is offline
