Fuel Sump Ideas - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 11-26-2012, 04:43 PM Thread Starter
Fuel Sump Ideas
Please excuse me if this has already been posted, butI have been tossing around the idea of a fuel sump lately. I did some looking and was wondering if i could use a Carter P4070 pump. Then use a a Napa 4770 filter base with a 3528 Napa Gold filter. Wondering if anyone else has done something similar to this? I know an Airdog system would be ideal but I don't have the funding at the moment. Also kicked around the idea of using the FRX I have mixed feelings about that. Any feedback would be much appreciated.
Thanks for your time.
nielsencod is offline
post #2 of 28 (permalink) Old 11-26-2012, 04:53 PM
the stryker god
Re: Fuel Sump Ideas
Sump, 10-25 micron pre pump filter, stock pump, 2-5 post pump filter regulated return.
bruce51d is offline
post #3 of 28 (permalink) Old 11-26-2012, 05:59 PM Thread Starter
Re: Fuel Sump Ideas
So just run the stock filter no need for the lift pump?
post #4 of 28 (permalink) Old 11-26-2012, 06:10 PM
the stryker god
Re: Fuel Sump Ideas
What are you talkin about
bruce51d is offline
post #5 of 28 (permalink) Old 11-26-2012, 10:34 PM Thread Starter
Re: Fuel Sump Ideas
Sorry to sound like such a newbie. When you use the dump you still need a pump to get the fuel to the stock pump right? I was gonna use the carter for that.
post #6 of 28 (permalink) Old 11-26-2012, 10:43 PM
the stryker god
Re: Fuel Sump Ideas
No, its called gravity
bruce51d is offline
post #7 of 28 (permalink) Old 11-26-2012, 10:52 PM
OSCS's Avatar
Re: Fuel Sump Ideas
If he installed a sump than the frame rail mounted fuel pump would be pretty much level
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #8 of 28 (permalink) Old 11-26-2012, 10:57 PM
OSCS's Avatar
Re: Fuel Sump Ideas
A sump will not slow down your fuel pickup, if anything it would help it by giving it a shorter path to the pump and not having to suck it through a straw up and out of your tank. Look around there are tons of write ups and threads regarding alternative filtering and delivery
OSCS is offline
post #9 of 28 (permalink) Old 11-26-2012, 11:34 PM
the stryker god
Re: Fuel Sump Ideas
Yeah but that would be at absolutely empty on fuel. The pump pulls a siphon thats how it gets fuel with a stock pick up. I have a sump its awesome because its super simple, nothin to mess up just gravity.
bruce51d is offline
post #10 of 28 (permalink) Old 11-27-2012, 02:03 AM
OSCS's Avatar
Re: Fuel Sump Ideas
I want one
OSCS is offline
