max safe power with pmr engine - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 11-20-2012, 01:29 AM Thread Starter
TURBO LIT 'N' THAT WAS IT
powerstrokin7.3's Avatar
ok im curious what is the highest horse power you can get out of a prm 7.3 and not have to worry about scattering it every time you feed it, and what do you need to do to hit those horse power numbers, (i.e. turbo, injectors, chip, ect.)
03 SCSB (TOTALED)
00 ccsb zf6, 4" exhaust, 6637, ts chip w/php tunes, tinted glowshift gauges, ats ported housing,RR, leveled, ccv mod, pp mod, zoodad, intake heater delete, ebpv delete, WW2, t-500, South Bend clutch, more to possibly come
powerstrokin7.3 is offline
post #2 of 37 (permalink) Old 11-20-2012, 01:31 AM
the stryker god
Re: max safe power with pmr engine
200, stock with no chip.
bruce51d is offline
post #3 of 37 (permalink) Old 11-20-2012, 01:39 AM Thread Starter
really? i see alot of pmr trucks with many mods, or are they jus taking a chance hoping it holds together?
03 SCSB (TOTALED)
post #4 of 37 (permalink) Old 11-20-2012, 01:40 AM
I've heard the limit is anywhere from 400-500. I guess it depends on the circumstances..
2002 F-250 CCSB 7.3L ZF6
6637, 4" MBRP- muffler MIA, Autometer Cobalts, PHP Phoneix chip, 6" lift, 35's on Weld Stonecrushers, McNeil Racing Bedsides and Fenders, 203* Stat., Frx, AmsOil...
02ccpsd is offline
post #5 of 37 (permalink) Old 11-20-2012, 01:47 AM
the stryker god
if you are a gamblin man then yeah you can try for 600, but if you want it to be 100 percent reliable then you leave it stock. there have been many pmr engines popped with just a chip. i've been makin 465 with pmrs for almost 3 years but i know its a risk
bruce51d is offline
post #6 of 37 (permalink) Old 11-20-2012, 01:52 AM
Very true..
02ccpsd is offline
post #7 of 37 (permalink) Old 11-20-2012, 01:56 AM
300,000 and counting's Avatar
If you have the money build a 450hp truck and hope it holds or put cryod forgded rods in it and then bigger.
38r
238/100 hybrids
reg return
dual sd fuel pumps or walbro
push rods
valve springs
upgrade tranny
gauges
intake
turbo back exhaust
custom tuning
Those mods will get you to 450hp; with pmr its hit or miss with your pmr breaking you could be a lucky one, at the same time it might come apart in the first 10 miles.
If you wanna go bigger get studs, 250/100 (or 250/200) injectors, cryod forgded rods, s467, srp1.1. You would be around 500-550hp
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #8 of 37 (permalink) Old 11-20-2012, 01:59 AM
International Coal Roller
jbwaldrop88's Avatar
I still consider a PMR 7.3 with a chip a safer bet than a stock 6.0
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #9 of 37 (permalink) Old 11-20-2012, 01:59 AM
the stryker god
how far is spring mills from meadville
bruce51d is offline
post #10 of 37 (permalink) Old 11-20-2012, 12:31 PM
<-- it's like that
Been running this setup now for more than a year and a half:
250/200's
38R
Intake
Exhaust
Home-built fuel system
BTS
6.0L intercooler
180K miles and counting on the stock PMR motor. I don't even have studs, pushrods, springs, etc.
My tuning does have a lot of fuel limiting at lower RPM's, even in my race tune (used on the dyno a few months ago). Numbers in my sig. Another guy at the dyno event had similar mods on his truck running forged rods. He made 1hp more than me, but well over 100 ft/lbs of torque. That's the difference in the fueling, and probably why my motor is still together.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
