7.3L Snow Performance TOW-MAX IMPRESSIVE. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 35 (permalink) Old 11-19-2012, 08:02 PM Thread Starter
I just purchased a Snow Performance Tow-Max Kit. The installation instructions are pretty easy going. They don’t really explain how to adjust the “gain”. I called Snow, left a message with technical support and they got right back to me and explained the correct operation. I choose to purchase the Air Intake Heater Delete Plug from Strictly Dieselhttp://www.strictlydiesel.com/p-2692...stall-kit.aspx. This plug is predrilled and machined down to make installation of the injector nozzle WAY easier. It also come with a special T fitting and lines. It’s a MUST HAVE. Snow wants you to remove you CAC pipe and drill/tap it. In my opinion the CAC pipe is too thin for a npt fitting. I choose to run one 625ml nozzle.
While towing I pulled the same hill twice. I got 150-170 degree Drop in EGT'S. I tried to make the truck run over 1200 degrees and could not do it. I am using -20 degree BLUE washer fluid from Napa. $0.99 a gallon when on special. This is by far your cheapest way to go for your mixture and already comes premixed. Unless you want to purchase 100% methanol and mix it yourself. Blue washer fluid gives me 30-36% methanol ratio PER MSDS... Any time you want to know methanol content of washer fluid look at the MSDS sheet.
MY CONCLUSION: You can definitely feel the power increase when the system starts to inject. You can also hear the engine change tone. It has a lot more power while pulling hills. I weight over 28k combined and need a little extra... I will have real world dyno numbers soon. I set my kit up in the medium boost setting “18-25psi”, I get No quenching at all in any of the settings. The System used right at two gallons on an 85 mile trip. I used right at 2 gallons. I saw NO INCREASE IN FUEL MILEAGE as claimed. I purchased the kit ONLY for more power and to keep my EGT’S manageable. I figured its like every other claim of increased fuel mileage. All in All VERY HAPPY with the way the Snow Performance kit performs.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #2 of 35 (permalink) Old 11-20-2012, 03:38 PM
Village Idiot
southmike's Avatar
Re: 7.3L Snow Performance TOW-MAX IMPRESSIVE.
You can adjust the washer meth ratio by looking at the cold weather chart...ie -20 , -10,0 etc.
Few charts on the net somewhere.
southmike is offline
post #3 of 35 (permalink) Old 11-20-2012, 07:44 PM Thread Starter
I cannot find a chart anywhere that shows the methanol content differences.
post #4 of 35 (permalink) Old 11-20-2012, 09:45 PM
Village Idiot
southmike's Avatar
http://www.pqgallery.com/sites/386487/reg/MSDS.
http://thelsxdr.com/wp-content/uploa...ethlisting.jpg
are a couple
There are many places to buy straight methanol, but if you are going to use a water/methanol mixture, the easiest (and cheapest) is to buy the blue windshield washer fluid that is used during winter time to prevent the fluid from freezing. It may sound cheap ($1.29-$1.99 per gallon),
but it is just as good as any methanol/water mixture you would make otherwise.
The blue is just a dye, and an extremely insignificant amount (<1%).
look for a companies MSDS's (Material Safety Data Sheets)
+20 F Washer Fluid - Contains approximately 7% methanol.
0 F Washer Fluid - Contains approximately 23% methanol.
-10 F Washer Fluid - Contains approximately 28% methanol.
-20 F Washer Fluid - Contains approximately 35% methanol.
-25 F Washer Fluid - Contains approximately 38% methanol.
-50 F Washer Fluid - Contains approximately 62% methanol.
post #5 of 35 (permalink) Old 11-21-2012, 02:00 PM Thread Starter
are a couple
Great information. Thanks I couldn't find anything.
post #6 of 35 (permalink) Old 11-21-2012, 06:50 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Keep in mind that noise your hearing is timing. The methonal is advancing your timing.
Try running straight water. It will keep the EGT's down more, and allow you to run more FUEL rather then methonal.
Not a fan of running washer fluid.
Joe
CSIPSD is offline
post #7 of 35 (permalink) Old 11-21-2012, 07:45 PM
Village Idiot
southmike's Avatar
Water is free just keep in mind it freezes...
Do you run any cutting oil Joe...?
post #8 of 35 (permalink) Old 11-23-2012, 03:09 AM
CSIPSD's Avatar
Yes.
Joe
CSIPSD is offline
post #9 of 35 (permalink) Old 11-24-2012, 05:39 AM Thread Starter
According to this video Snow Performance produced. Water methanol does NOT change injection timing.
post #10 of 35 (permalink) Old 11-25-2012, 09:43 PM Thread Starter
Originally Posted by toypuller View Post
http://www.youtube.com/watch?v=nn9LxE3KU_4
So What do you all think.
Joe What are you using for cutting oil?
Closed Thread
