Looking for more power! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 11-17-2012, 10:32 PM Thread Starter
2000 F350 CCLB!!
Day-Day's Avatar
I have a 2000 F350 CC Long bed as of right now my upgrades are
-AFE stage 2 colde air intake
-5" turbo back straight pipe
-DP tuner
-4 gauge pod
-and a baby lift with 37" tires
Im looking for a little advice about some preformance upgrades i have a rough idea of what i want to do but no idea witch order or what exactly is hould be looking for.
id like to do the 38r turbo, new injectors was thinking stage 2, and i know id have to upgrade the tranny to eb able to handle the hp so either a whole new tranny or just a few upgraded parts in stock.
also was looking at intercoolers, and upgrading the HPOP
Any help and advice would be apriciated for ive read the newbie looking for power forums and i was just lookign for a little bit more help specific to ME! ha thank you.
Day-Day is offline
post #2 of 34 (permalink) Old 11-17-2012, 11:04 PM
biggreen96's Avatar
Re: Looking for more power!
Best thing to answer is what are your HP goals . Then we could help you with your questions. As for transmission your going to want a tc and valve body upgrade at the least.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 34 (permalink) Old 11-17-2012, 11:30 PM
300,000 and counting's Avatar
first you need to decide a horsepower, If it was me and since you wanna go with a 38r I would go with 238/100 hybrids, walbro fuel pump, and a reg. return for starters that should get you around 425-475hp. Also you might wanna go with 910 comp sprinds and push rods to keep the top end safe.
Unless your hpop is weak you wont need a bigger one and i pefer water meth over an intercooler but you dont really need either one for a daily driver and water if you tow a good bit. As for tranny get a bts valve body and when your tranny goes have bts build you one and he will take the $250 for the valve body
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #4 of 34 (permalink) Old 11-18-2012, 01:16 AM Thread Starter
2000 F350 CCLB!!
Day-Day's Avatar
End goal id like to be pushing 500-550HP should i not be lookign at the 38r? so would it be better just to upgrade the TC and valve body then go with a whole new tranny?
Day-Day is offline
post #5 of 34 (permalink) Old 11-18-2012, 01:53 AM
the stryker god
250/200, s467, srp1.1, dual sd fuel pumps with regulated return, bts, head studs, valve springs. Lots of stock forged rods poppin at that level. Prolly about 10-15 dependin on labor.
bruce51d is offline
post #6 of 34 (permalink) Old 11-18-2012, 03:46 PM
bruce is right on the 500-550hp if your going for that much power do the tranny soon, if your going the route I was talking you can just upgrade your valve body for the time being it will keep your tranny together alittle longer but you will end up getting it completely redone at some point.
post #7 of 34 (permalink) Old 11-18-2012, 04:36 PM
Village Idiot
southmike's Avatar
Mild ...t500 hpop, st 1 injectors valve body and torque converter. Have Jody retune.
Fun...Sgt2 injectors t500 or adrenaline hpop same tranny mods and reburn.
Lotts of fun .....gt38r turbo and 238 injectors (did has a combo) tranny mods and reburn...hold just a bit back if no valve springs or studs....add those for insurance and think about a bts or similar tranny.
After that sky or wallet is the limit.
Hpop, turbo mods , regulated return, are always useful mods..at any power level.
Dual fuel pumps , studs, valve springs are handy at over 450 hp or so.
southmike is offline
post #8 of 34 (permalink) Old 11-18-2012, 06:29 PM Thread Starter
2000 F350 CCLB!!
Day-Day's Avatar
Thank you I'm looking into the tranny now would like todo that at te same time as turbo and injectors insurance will have to come in a few weeks thank you
2000 F350 CCLB
-4" Skyjacker riding on 37's
-AFE stage 2 cold air intake
-5" straight pipe
-DP tuner
-Glowshift Gauges
Day-Day is offline
post #9 of 34 (permalink) Old 11-19-2012, 12:11 AM
BTS in $4500
post #10 of 34 (permalink) Old 11-19-2012, 03:23 PM
Old Yeller, REBORN
kilapapipa's Avatar
Do the valve body if your not doing the whole tranny. Don't spend the money on a TC that you won't be able to reuse when the whole tranny craps out. Trust me on this one.
Southmike, don't install that ARI if you haven't already. I think it is junk.
I have $2000 wrapped up in a JW valve body(still using), ARI TC(Junk) and 2 used trannys(one in and one waiting to get used) Had I just saved up, I could have gotten a BTS and saved some headache. However, I can change out a tranny, just a TC, or valve body like making a sandwich now so I learned a lot.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
