Turbo questions. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-15-2012, 09:13 PM Thread Starter
Turbo questions.
Looking for a good turbo that has the capability of making good power (nothing to crazy) and that whistles nice and loud and also maybe a few other things I could ad to help it out such as cold air intakes and such. Thanks guys!!
Tylers7.3 is offline
post #2 of 13 (permalink) Old 11-15-2012, 09:14 PM
Re: Turbo questions.
38r
countryboyrob is offline
post #3 of 13 (permalink) Old 11-15-2012, 10:18 PM
38R turbo's Avatar
38R and a 6637 intake and you will have all the whistle you can handle and will allow for power increases.
2000 F250 CC SB 4x4, 7.3 diesel, 4R100, 4"lift, AIS intake, 38R Turbo, Turbonetics outlet, Swamps 200/30 Hybrids, Swamps tunes, Swamps IDM, 4" MBRP, BTS valvebody, 6.0 cooler, ISSPRO fuel press, boost, egt, trans, water temp, ScanGage, Melling Lpop, FRx, Hutch mod, spin on filter/separator, Bosch pump, DIY 3/8 fuel lines, OCR, HPx, Autoenginuity.
38R turbo is offline
post #4 of 13 (permalink) Old 11-16-2012, 12:21 PM
X3.............you may want to add bellowed uppipes and a non evb base.
Tymar Intake will let it sing....
We have all..PM me if I can help.
email:
Website:
OBSWIZ is offline
post #5 of 13 (permalink) Old 11-16-2012, 07:13 PM
Old Yeller, REBORN
kilapapipa's Avatar
Two options: 38r or 38r.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #6 of 13 (permalink) Old 11-17-2012, 04:55 AM Thread Starter
Ok thanks guys was also thinking a set of injectors while I had the head off to stud I was thinking 100hp is that to big or to small? And are there any types of delets I should be doing
post #7 of 13 (permalink) Old 11-17-2012, 05:36 AM
Whoever is selling you 100hp injectors...... Stay away from them. Psd injector builders don't use HP to rate the size of them, they use how Mich cc's of fuel they flow and the % over stock the Nozzles flow.
post #8 of 13 (permalink) Old 11-17-2012, 12:47 PM
Old Yeller, REBORN
kilapapipa's Avatar
Also don't remove the heads and disturb the gaskets just for studs. Its been done before one at a time.
post #9 of 13 (permalink) Old 11-17-2012, 02:13 PM Thread Starter
So I can change the studs without pulling heads? And yea I changed and got stage three injectors that are measured in cc
post #10 of 13 (permalink) Old 11-17-2012, 03:05 PM
Old Yeller, REBORN
kilapapipa's Avatar
Yes. Research it. There are some tricks to it but it works. Research a usename Vanderchevy I think. Irememer him doing it.
