Adrenaline HPOP question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 11-15-2012, 08:11 PM Thread Starter
How much gain would I see on a truck with the following mods:
Banks: 1.0 exhaust housing, big head wastegate, compressor wheel, 3.5"downpipe and exhaust,
AFE: stage 2 air intake system
Air Intake Heater delete, Exhaust back pressure valve delete, superchips tuner, fuel pressure crossover, oil crossover
572ysc is offline
post #2 of 18 (permalink) Old 11-15-2012, 08:13 PM
Re: Adrenaline HPOP question
wont really see a difference.....
Ditch the oil crossover as well.
countryboyrob is offline
post #3 of 18 (permalink) Old 11-15-2012, 11:57 PM
the stryker god
You'd be better of gettin new tunes or steppin up to some 160's
bruce51d is offline
post #4 of 18 (permalink) Old 11-16-2012, 12:00 AM Thread Starter
Wouldnt new tunes push me past 32lbs of boost? I am already hitting 32lbs on a stock turbo.
572ysc is offline
post #5 of 18 (permalink) Old 11-16-2012, 12:06 AM
the stryker god
Then get a 38r
bruce51d is offline
post #6 of 18 (permalink) Old 11-16-2012, 12:08 AM Thread Starter
Well the reason I was wondering about the adrenaline or the stealth is because my current stock hpop is leaking in the rear.
572ysc is offline
post #7 of 18 (permalink) Old 11-16-2012, 12:20 AM
the stryker god
T500 is cheap but does a good job, stealth is a bad mofo but is prone to problems but it has a good warranty
bruce51d is offline
post #8 of 18 (permalink) Old 11-16-2012, 04:25 AM
Demon Dually
speeddemon31176's Avatar
Either the Adrenaline or the T500 will do the trick with anything up to stage 2's and some guys I believe are running hybrids with them without issue. As far as turbo goes, I would recommend stepping up to something like a D66 or H2E at the least.
speeddemon31176 is offline
post #9 of 18 (permalink) Old 11-16-2012, 12:04 PM
What year is your SD...filling out your sig helps get correct answers.
Gain............depends which HPOP you have, with hot tunes your 15-17* will not keep up with the demands of split shots HPO. So a better HPOP can help.
Keep the crossover helps #8 with its oiling needs.
email:
Website:
OBSWIZ is offline
post #10 of 18 (permalink) Old 11-16-2012, 01:11 PM
OBS Stroker
Nodge's Avatar
Stage 2 or even stock split shots need more high pressure oil than a hybrid. A stock 15* pump can run a set of hybrids well. That's why hybrids are a good choice over a stage 2.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
