Sorry guys ccv mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 11-14-2012, 10:58 PM Thread Starter
fpOwerstRokeD's Avatar
Sorry guys ccv mod
I used the search function I just can't find what I need and I'm just looking for a DIY ccv mod write up 03 7.3 ecsb F250 maybe some pictures too if possible thanks !
03 F-250 lariat 7.3,ZF6,gauges,6637,banks exhaust brake(came with the truck). FASS fuel system.
fpOwerstRokeD is offline
post #2 of 9 (permalink) Old 11-14-2012, 11:42 PM
19stroker97's Avatar
Re: Sorry guys ccv mod
Welcome to guzzle's CCV mod web page
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #3 of 9 (permalink) Old 11-14-2012, 11:57 PM
dkrajcovic
4" ext pipe & 3/4 to 3/4 90* fitting & some 3/4 hose & new o-rings to install when you flit the ccv cap
hope this helps
2000 f350 drw, grages, 4" down pipe, 4" dp back , FRx, 6637 filter, ccv kit, PHP tuner
dkrajcovic is offline
post #4 of 9 (permalink) Old 11-15-2012, 12:14 AM
jtgf250's Avatar
Hey man I wrote a thread on it not long ago. Pull the dog house and clean it out really well (brake clean, parts washer, contact cleaner) just get it were what ever you clean it with comes out clean no more oil. Flip it around and run a piece of 3/4 heater hose out of it over your brake booster down behind the motor pointing down. (down draft tube) Then pull the piece out of your intake hose that the dog house went into, replace with a piece of 4" pipe about 3-1/2" long. Thats it. No more oil in the turbo and clean boots. If you clean the dog house out good no need for a vent trap. I dont have any oil coming out of mine and all clean. Good luck
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 9 (permalink) Old 11-15-2012, 11:40 AM Thread Starter
thanks fellas getting to it this weekend !
post #6 of 9 (permalink) Old 11-15-2012, 12:12 PM Thread Starter
jtgf250 what kind of pipe did you use exhaust ? pvc ?
post #7 of 9 (permalink) Old 11-15-2012, 07:00 PM
Demon Dually
speeddemon31176's Avatar
PVC, copper, aluminum, steel, etc. Doesn't really matter what type of pipe you use. I used a 3/4 x 3/4 plastic nipple on mine. Worked just fine.
speeddemon31176 is offline
post #8 of 9 (permalink) Old 11-15-2012, 07:06 PM
Old Yeller, REBORN
kilapapipa's Avatar
Get a 3/4" rubber cap for the intake. You rotate the doghouse so it won't interfere with anything.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #9 of 9 (permalink) Old 11-15-2012, 10:18 PM
jtgf250's Avatar
I just stopped by a metal shop and got a piece of scrap for like ten bucks, got a piece long enough to make another for a buddy. It was like 1/8" thick probably less. You can cap off the factory piece, but I just wanted to git rid of any air disruptions. Polished the pipe with a flapper wheel and painted it black, looks factory. Fits nice and snug between my afe stage 2 intake pipe and the turbo inlet house, didnt need to make anything to bolt it in for support as some have done, it aint going anywhere. Used a straight 3/4 coupling to tie to the dog house with some hose clamps.
jtgf250 is offline
