Up-pipe recommendations - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 09-08-2007, 01:16 AM Thread Starter
<-- it's like that
Well I'm the kind of person when something breaks, I don't replace it, I upgrade it.
This morning while washing the engine I saw a very small soot trail on the driver's side up-pipe just under the donut gasket. Drove it around today and checked again, now I"ve got the pipe covered in soot and it's starting to collect on the firewall. Apparently I caught the leak right as it began, but it's getting worse fast.
So I need recommendations on new up-pipes. I'll be trashing the stock ones and looking for something better that won't be prone to leaking again. Hit me up with what you're running, price, why you like (or dislike) them, etc.
Thanks!
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #2 of 29 (permalink) Old 09-08-2007, 01:35 AM
Haul_n_horses2's Avatar
Re: Up-pipe recommendations
If you have the Garrett turbo or another drop in and have OEM up pipes, the best upgrade is to IH upgraded bellows up pipe and collector. BWD sells them ceramic coated which is probably a good idea. Pics on Brian's site. Or you can get uncoated pipes at your local IH dealer.
Haul_n_horses2 is offline
post #3 of 29 (permalink) Old 09-08-2007, 01:35 AM
I'd get ones with the bellows in them. The stock T444E parts from Navistar are good for the money.
Or BWD has a nice kit that is coated as well.
69W900A is offline
post #4 of 29 (permalink) Old 09-08-2007, 02:01 AM
I belive DI has a set out with bellows in them.
hotwheels is offline
post #5 of 29 (permalink) Old 09-08-2007, 02:11 AM
Corona Killa
THEDIESELMAN's Avatar
Yep if I need some I would go with the ones that BWD sells.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #6 of 29 (permalink) Old 09-08-2007, 02:20 AM
Banned
Does David still sell the Stainless one piece assembly with the stainless bellows?
That is by far the best solution IMO. No sh#t to have to bolt together or any kind of seal anywhere to ever blow. V-band flange at the top and the flares on the manifolds at the bottom.
I'm sure they're probably more expensive, but they're tough as nails too.
Good Luck.
Charles is offline
post #7 of 29 (permalink) Old 09-08-2007, 02:28 AM
I agree. The DI kit is nice, though I'm not sure on the availability?
I used the IH 444E with the bellows that BWD sells. We'll see how they hold up.
TerminatorEngineering is offline
post #8 of 29 (permalink) Old 09-08-2007, 03:16 AM
OEM Moderator
Tom S's Avatar
Joey do you have that on the obs truck?
Tom
Tom S is offline
post #9 of 29 (permalink) Old 09-08-2007, 03:20 AM Thread Starter
<-- it's like that
So far everywhere I've posted the response has been BWD. Looks like a lot of people have been satisified with that setup. I remember seeing pics of the DI setup from David, but I never knew if they were ever released.
Someone asked me to do a writeup on the up-pipe swap. If there's interest I'll post it here too, or send it to Guzzle and he can add it to his page. Or I'll get lazy and make a trip to go see Rocky again.
Curtis
2002 F-250 PSD
Pocket is offline
post #10 of 29 (permalink) Old 09-08-2007, 03:26 AM
Good Luck.
I believe they are a little more expensive but worth it I feel. There was no BS trying to bolt this to that, they fit perfect.
JMS1 is offline
