Does size matter?......Intake plenum size that is - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-06-2007, 10:11 PM Thread Starter
<- Sums it up
strokin_early_99's Avatar
Like the title asks. Does it make a noticeable difference to go with the 3" intakes. I have do decide if I am going to change them now or wait for the new block going in next year.
Next question...
I have Stealth big oil, can it be done without taking out the twin pumps? Has anyone done it? Any pointers?
Thanks
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #2 of 16 (permalink) Old 09-07-2007, 12:36 AM
Re: Does size matter?......Intake plenum size that is
you have to pull the pumps to get the bottom plenum bolts out. I just put plenums on in the truck not too long ago. With the pumps and turbo out it wasn't too bad of job. Worst part was getting the pass side plenum broke loose. Beans billet plenums will clear the pumps w/o any modifications.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #3 of 16 (permalink) Old 09-07-2007, 01:44 AM
South Atlanta white trash
Doodie's Avatar
I'm running Bean's plentums. My stock ones would crush when I tried to tighten the boots. Looks better too.
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #4 of 16 (permalink) Old 09-07-2007, 03:02 AM
Don't EFN worry about it
Aljay's Avatar
Ok but nobody answered the question do the 3" plenums make a difference in power or not?
Tuned by T Wildman
Aljay is offline
post #5 of 16 (permalink) Old 09-07-2007, 03:06 AM
Can't hurt. The SD's went big for a reason, so I finally changed mine on the 95(Stock SD's). I haven't noticed any difference yet.
TerminatorEngineering is offline
post #6 of 16 (permalink) Old 09-07-2007, 03:20 AM
Needs more hours per day
jtharvey's Avatar
Removing a restricting can't hurt anything. I just wonder how much it helps, since air's being forced through them rather than being sucked through them.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #7 of 16 (permalink) Old 09-07-2007, 03:20 AM Thread Starter
<- Sums it up
Thank you Aljay and Thank you Joey for the info. With that I think they will have to say until I put in the new block.
Did you change then with termy in or out of the truck?
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #8 of 16 (permalink) Old 09-07-2007, 03:22 AM
Aljay's Avatar
Thanks for the reply. I am going to swap the intakes when I go to the 38r just wanted to see if anyone actually noticed a difference.
Tuned by T Wildman
Aljay is offline
post #9 of 16 (permalink) Old 09-07-2007, 03:25 AM
Howard, I pulled the pumps and updated them. I figured I might as well run the latest upgrades on my truck too!
post #10 of 16 (permalink) Old 09-07-2007, 03:27 AM Thread Starter
<- Sums it up
I am going with a larger than normal turbo and was wondering the same thing. BWD said it would help things breath but did not say how much and is designing a mounting kit for my early 99 intakes but had not confirmed the order yet. Another shop said it was less than a 5&#37; gain going larger.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
