h2e ex housing ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-29-2008, 03:58 AM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
h2e ex housing ?
ok i got a 19cm on it now and was a great step up from the 17. my question is that was w/ 80%nozzles on my hybrids, so now i got 200% nozzles and was wonderin if the 19 was a good match or if something like a 21 would be better? also the charger is not modified in anyway. maybe someone thats run both? thanks for the input
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 11 (permalink) Old 07-29-2008, 04:04 AM
What else?
smokyred's Avatar
Re: h2e ex housing ?
Check your drive pressure, if it's a fair amount higher than your boost, try stepping up to a 21cm.
When I was going to run an H2e, 275's and my auto, it was suggested that I run the 19cm and get a feel for it, and then try the 21cm because of the auto. I never ran my H2e though, so I'm not sure how it would have worked.
Dave
smokyred is offline
post #3 of 11 (permalink) Old 07-29-2008, 04:06 AM
Oooo, White Lightning !
Dieselboy's Avatar
If you go to the 21 let me know.......I have the 17 and am throwing a set of 230cc hybrids in, I may want that 19
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #4 of 11 (permalink) Old 07-29-2008, 04:09 AM Thread Starter
Crazy Talk
ok. ya if you can find one do it. i will say it smokes more down low, but lites at the same rpm and same max boost.
can i accuratly measure back pressure if i take the back press. sensor out and plumb a guage there?
post #5 of 11 (permalink) Old 07-29-2008, 04:18 AM
Dieselboy's Avatar
I know of one person with a modded H2E (66m) that runs B codes makes just over 500 HP with the 19cm
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #6 of 11 (permalink) Old 07-29-2008, 04:20 AM Thread Starter
Crazy Talk
but it probably is modded on ex side as well, how much does that change things?
ill see if i can get some back press. readings tomm. when i get it back together.
post #7 of 11 (permalink) Old 07-29-2008, 04:23 AM
i run a 19 with the twins, but i have a 21cm here to try. Im not sure what the backpressre was with the mod h2 and the 17 but it made 550 on fuel. never dynoed the 19cm housing on fuel but it feels better than the 17 did. im going to hook a backpressure gauge with the 19 and see how things look then do the same with the 21
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #8 of 11 (permalink) Old 07-29-2008, 04:24 AM
Dieselboy's Avatar
When people refer to the modded H2E Im pretty sure the just change the comp wheel and comp housing...........The exhaust housing stays the same as far as the wheel ?
so technically a 17cm off of my 62mm H2E would work with a 66mm Modded H2E and vise versa
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #9 of 11 (permalink) Old 07-29-2008, 04:25 AM Thread Starter
Crazy Talk
ok great let me know. haha i listened to you on the 19 and glad i did.
post #10 of 11 (permalink) Old 07-30-2008, 12:42 AM
Pearson's Diesel
smokin dually's Avatar
I ran a 17 on my 66mm and blew the headgaskets. I went to a 25cm housing and 3" exhaust wheel to get the drive pressures back under control, but now the street manners suck. If anyone has a 19 housing they would like to get rid of let me know.
01 F350 cc dually 6sp conversion
00 F250 2.6 puller
early 99 F350 2wd daily driver
smokin dually is offline
