Compound Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 50 (permalink) Old 07-28-2008, 05:02 PM Thread Starter
HP Junky
Compound Question
I had the opportunity to drive an 06' Common Rail with an S300/S400 compound turbo set-up on it this past weekend. Truck dynos right at 600hp in it's current stage. The chargers worked awesome on there, instant spool-up and no need for a pyrometer.
Knowing next to nothing about compound set-ups is there any reason those wouldn't work on a 7.3L? I would think that with a larger displacement engine they would work even better on the Powerstroke. But like I said, I don't know much, thats why I'm asking.
The S300 has mutliple set-up options (i.e inducer, comp wheel, turbine options) and the same goes for the S400. Either can be upgraded pretty easily to flow just about any amount of air. Plus the chargers are cheap in comparison to others on the market. I'm just curious is all.
RockinJW is offline
post #2 of 50 (permalink) Old 07-28-2008, 05:10 PM
JD Dearden's Avatar
Re: Compound Question
What do you want to hear belt buckle
2006 Triple Turbo Dodge
7.3 injectors are like greeters at wal mart. They are there and they do there job, but you can't ask them to do anything quickly or they will get confused and give up.
JD Dearden is offline
post #3 of 50 (permalink) Old 07-28-2008, 05:11 PM
moore20017.3's Avatar
Probably work out pretty well. Get to it!
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #4 of 50 (permalink) Old 07-28-2008, 05:12 PM
Id think that the chargers would need different/ bigger exhaust housings but other than that i dont know why they wouldnt work.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #5 of 50 (permalink) Old 07-28-2008, 05:51 PM Thread Starter
HP Junky
Well, this is just my thoughts. You can get the S300 in a 62mm then put a t-4 flanged turbine housing, not sure of a/r though. As for the S400, I think you can get it in a modded version in a 80mm inducer and 1.32 turbine.
Not looking to build a big set of compounds for unlimited horsepower. But something for a good streetable daily driver, say 600hp.
RockinJW is offline
post #6 of 50 (permalink) Old 07-28-2008, 06:45 PM
Oooo, White Lightning !
Dieselboy's Avatar
Wouldnt it be more benefitial for you to just keep your 42R and run like a 38R in front of it......
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #7 of 50 (permalink) Old 07-28-2008, 06:48 PM Thread Starter
HP Junky
Don't believe the 42 is big enough, it's only 74mm.
RockinJW is offline
post #8 of 50 (permalink) Old 07-28-2008, 08:54 PM
Banned
It's not...
IMO of course
Charles is offline
post #9 of 50 (permalink) Old 07-28-2008, 09:00 PM
Wasnt 550 hp too much for u before???
Diezel Dawg is offline
post #10 of 50 (permalink) Old 07-28-2008, 09:02 PM
Ya, it's a couple mm's to small......
TerminatorEngineering is offline
