38r drive pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-28-2008, 12:03 AM Thread Starter
38r drive pressure
Would I be correct to assume that drive pressure is lower with a 1.15 A/R vs. a 1.0 A/R? If so what is the difference at say 35 lbs boost?
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 15 (permalink) Old 07-28-2008, 03:09 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: 38r drive pressure
With the 1.00 housing I saw 30# boost vs 45# drive pressures... With the 1.15 housing it was 30# to about 35-37# drive pressures.
This was with the 38r...
Joe
CSIPSD is offline
post #3 of 15 (permalink) Old 07-30-2008, 02:04 AM
charlie99's Avatar
I thought it was much more efficient than that
'95 PSD 3" RSK, 3" bodylift, 37x13.50x20 xterrains. Tymar intake,ARP studs, comp 910s, DIY 238 hybrids with 200% nozzles, 6.0 intercooler, 3.5" downpipe to dual 4" stacks, CCV mod, IDM mod, DP tuner mod stock, 40t, 80e, 140r, fass 150/180, ITP regulated return, TE big oil, GTP38r turbo, lookin for 500 ponies
charlie99 is offline
post #4 of 15 (permalink) Old 07-31-2008, 02:06 AM Thread Starter
yea i've got a 38r ready to go in with the 1.0,I'm just looking for a good reason to justify a few extra clams for the 1.15. I'm seldom at WFO unless pulling a trailer so I'm not sure how useful or needed this is for Me. The thought of less parasidic HP loss sounds good and as Charles said the sound of an exhaust with the 1.15 makes it very worthwhile.
post #5 of 15 (permalink) Old 07-31-2008, 02:10 AM
Banned
I would NEVER install a 38R with the 1.0 unless I couldn't get the 1.15
It is just much happier IMO. It's not the end of the world to swap them later though. Run it with the 1.0 then the 1.15 and draw your own conclusion. If you don't like the 1.15 send it to me and I'll put it on my 550.
Charles is offline
post #6 of 15 (permalink) Old 07-31-2008, 02:11 AM
CSIPSD's Avatar
The 1.15 is the only way that turbo should be sold... Makes more power with lower EGT's across the board. Its still in my wifes X with the 1.15 and 37's with 3.73's...
Joe
CSIPSD is offline
post #7 of 15 (permalink) Old 07-31-2008, 02:19 AM
MudSouth's Avatar
I was right there on the edge too...Until I saw this thread. Two very knowledgable guys making such a strong recommendation has convinced me. I'm mostly looking to reduce the egts a little bit more.
2010 6.4 LB CC 4x4
ROLL TIDE!
MudSouth is offline
post #8 of 15 (permalink) Old 07-31-2008, 04:29 AM
I don't remember my drive pressure with the 1.15 but know it was real close to 1:1 under most conditions while live tuning and I believe it hit about 38 at 33 during a good run. EGTs are a non-issue now. I rarely look at that gauge anymore.
Tenn01PSD350 is offline
post #9 of 15 (permalink) Old 07-31-2008, 01:20 PM
How aare you guys measuring drive pressure? I can see back pressure.
Thanks.
Muley is offline
post #10 of 15 (permalink) Old 07-31-2008, 03:27 PM
CSIPSD's Avatar
Thanks.
Same thing for the most part... What is the pressure at the turbo inlet, or in the manifolds...
Joe
CSIPSD is offline
