Hydro lock after injector swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 07-27-2008, 09:15 PM Thread Starter
charlie99's Avatar
Just changed my injectors and I thought I had the cylinders good and purged, go to start and it won't turn over, tried just bumping the key to get it to roll past, but no go. What is the best way to get past this situation.
'95 PSD 3" RSK, 3" bodylift, 37x13.50x20 xterrains. Tymar intake,ARP studs, comp 910s, DIY 238 hybrids with 200% nozzles, 6.0 intercooler, 3.5" downpipe to dual 4" stacks, CCV mod, IDM mod, DP tuner mod stock, 40t, 80e, 140r, fass 150/180, ITP regulated return, TE big oil, GTP38r turbo, lookin for 500 ponies
charlie99 is offline
post #2 of 38 (permalink) Old 07-27-2008, 09:19 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
Re: Hydro lock after injector swap
roll it over by hand with a breaker bar a few times.. should free up just fine.. i have had to do that a few times... unless you want to do it the hard way and pull the glow plugs on a few cylinders..
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #3 of 38 (permalink) Old 07-27-2008, 09:26 PM
<- Sums it up
strokin_early_99's Avatar
Make sure to change the oil after all this.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #4 of 38 (permalink) Old 07-27-2008, 09:28 PM
ARMY bound
Yup just turn it slowly with a breaker bar and the fluids will seep past the rings. But make sure you change your oil! It's gonna have fuel in it now.
bbbxcursion is offline
post #5 of 38 (permalink) Old 07-27-2008, 09:33 PM Thread Starter
charlie99's Avatar
Just waiting for the rain to pass and I will go give it a try. thanks guys.
post #6 of 38 (permalink) Old 07-27-2008, 09:56 PM
Taters #2 Fan
JohnDeere9610's Avatar
Send a message via AIM to JohnDeere9610 Send a message via Yahoo to JohnDeere9610
pull the glow plugs I think is the easiest
RDRCM# Five O
95 F350
Full Force stage 3 Hybrids
H2E
2L Motorsports Gen 3
Beans fuel system
Transmission by Jon Faubion
Tuned by the "WILDMAN"
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
JohnDeere9610 is offline
post #7 of 38 (permalink) Old 07-27-2008, 09:59 PM
RDRCM
CooterBrown's Avatar
pull the glow plugs, disconnect the valve cover harness and turn over with the key multiple times.
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #8 of 38 (permalink) Old 07-27-2008, 10:01 PM
Taters #2 Fan
What dumb dumb said
RDRCM# Five O
95 F350
H2E
Beans fuel system
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
post #9 of 38 (permalink) Old 07-27-2008, 10:09 PM
I make no power
Diezel Dawg's Avatar
So i am guessing you should pull the glow plugs and unplug the harness to get everything out of there and crank it prior to putting everything back together to prevent it from doing what the OP said has happened?
99.5 PSD 4x4, GTP38R BB TURBO, DP-Tuner, AFE Stage 2, 6.0L IC, MBRP 4" Turbo Back w/6" tip,
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Stage 2/3 Injectors or B-codes, Big Oil, BTS or JW tranny
Diezel Dawg is offline
post #10 of 38 (permalink) Old 07-27-2008, 10:11 PM
PSN Mega Miler
crowz's Avatar
Id definitely go with the glow plug pulling method. Has to be safer.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
