Intercooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-27-2008, 03:24 PM Thread Starter
shopteacherguy's Avatar
Intercooler
I was wondering if anyone has installed an intercooler from a 6.0 into a 7.3. I have read that there are benefits because it is a larger intercooler. Does this work and if so what am I really going to benefit from the swap?
99 F250
4" Dynamax, Quad pillar pod guages, Edge Programmer, K&N air filter, Bed Rug, Air bags.
Swapped leather seats (pwr and heat!)
0-60 in 6.2 sec
1/4 mile 14.93 @95 MPH
shopteacherguy is offline
post #2 of 5 (permalink) Old 07-27-2008, 03:47 PM
fords4life's Avatar
Re: Intercooler
I did the swap, but that was before I had an EGT gauge. From everyone that I heard from you should expect a 50-75 degree temp drop with the 6.0 intercooler. The biggest issue involved with the swap is the tranny cooler lines. Some people have had issues with the 6.0 IC not clearing the factory 7.3 tranny cooler lines. Mine were tight, but it fit.
1999.5 F-250 XLT Crew Cab Short Box
4X4 7.3L Powerstroke
fords4life is offline
post #3 of 5 (permalink) Old 07-27-2008, 09:13 PM
Re: Intercooler
depending on your goals HP wise, the 6.0 cooler will work just fine, if u are going for big HP, then u might want to upgrae to a Spearco or DI intercooler. But if u can get it for about $150 or so, yea it is worth it for up to 100* drop.
Diezel Dawg is offline
post #4 of 5 (permalink) Old 07-27-2008, 11:12 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Re: Intercooler
The swap is worth it for a cheap 100 degree drop. But if your after hp you need something a little more durable.
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #5 of 5 (permalink) Old 07-28-2008, 01:10 AM
Village Idiot
southmike's Avatar
Re: Intercooler
dieselitesite has the boots for the swap
southmike is offline
