Who's using Evans coolant?` - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 07-26-2008, 12:57 AM Thread Starter
Just curious. I use it in my bikes, and it works great. I'm thinking about using it in my truck.
If your using it, have you had good luck w/ it?
99 F350 CCLB
skav is offline
post #2 of 18 (permalink) Old 07-26-2008, 01:08 AM
Drink til she's cute
Thuglike's Avatar
Re: Who's using Evans coolant?`
I use it!! Love it. Been 3 years now. Works as advertised!!!
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #3 of 18 (permalink) Old 07-26-2008, 01:19 AM
Orezona's Avatar
I don't remember. What is the advantage?
Orezona is offline
post #4 of 18 (permalink) Old 07-26-2008, 01:28 AM
Haul_n_horses2's Avatar
I ran it for about 80K miles. Despite the absence of silicates and cladding agent that protects the cylinders against cavitation damage, my water pump was on it's way out at 86K miles. AutoJim explained to me that the increased viscosity of the Evans required a different waterpump to achieve the same transfer of heat from the engine as the less viscous water based coolants. Further the waterpump bearing/seal is designed to be operated under pressure as a low pressure zone will develop around the shaft and may diminish the lubrication of the bearing/seal. I now have Chevron Delo EC-1 and it is easier to find than Evans. In a pinch I can just add water.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #5 of 18 (permalink) Old 07-26-2008, 02:44 AM
ARMY bound
I ran evans in both my vented engines
bbbxcursion is offline
post #6 of 18 (permalink) Old 07-26-2008, 03:51 PM
Snowman269's Avatar
I have Evans in my F350, probably 3 years now, it doesn't appear to get darker like most coolants do. I'm guessing the lack of water = lack of rust. It is supposed to handle heat better.
Once I read AutoJim's concerns, & I hadn't yet installed Evens in the Excursion, I went with Chevron ELC (Red Stuff). It also stays fluid in extreme cold where Evans turns to gelatin, which was a bigger concern for me.
Basically no real issues with either. I like not having to check the coolant for SCA's
02 7.3 X 4x4, MBRP 4",X & C Codes, RR Bags, Hellwig, 203 stat, tnk Mods
01 7.3 F350 CCLB 4x4 MBRP 4", BTS Trans, US Gear UD, DP 6 pos chip, V10 TCooler, 203 stat, DI reg Return, GT38R BB, AFE 2, Banks IC, Air Rite Bags,
96 F250 CCSB 4x4, 03 axles springs, rsk, ffd stage 2's, adrenaline, swamp tunes, bts trans, bdp fuel, diy IC
Snowman269 is offline
post #7 of 18 (permalink) Old 07-27-2008, 02:13 AM Thread Starter
Maybe that's the reason both are breezy
99 F350 CCLB
skav is offline
post #8 of 18 (permalink) Old 07-27-2008, 02:14 AM Thread Starter
Has anyone actually had cooling issues, and used Evans or ELC w/ positive results?
99 F350 CCLB
skav is offline
post #9 of 18 (permalink) Old 07-27-2008, 03:50 AM
ARMY bound
never had an issue before or after the swap.
post #10 of 18 (permalink) Old 07-27-2008, 06:48 AM
I tried Evans in a race engine and due to the heat transfer properties it does not transfer as much heat from surfaces compared to water-mixed coolants.
I wouldn't spend the money on it, a good long life coolant for diesel engines is cheaper and works good. Even with the exsisting pressure caps in place the PowerStrokes don't tend to have issues with coolant leaks.
69W900A is offline
