Boost pressures between cam sensors, there is a difference! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 07-25-2008, 10:41 PM Thread Starter
matthewd11's Avatar
I just swapped out my black cam sensor from napa because the truck started stalling randomly a few times a day. I installed the ford grey one and the truck now makes 3-4 less psi than the black one. Does that make any sense? Also take into consideration, i tested it as soon as i got off the highway after running the truck for about an hour. I wonder if heat soak had a hand in the less boost?? Truck is making about 41-42 psi of boost pre I/C. It was making 44-45 prior to testing. Should i wait until the truck is a bit cooler to test again? For reference, it makes 38 psi in my 80 setting. The prior numbers were in my 140 setting. I'm thinking the oil was too hot and my ICP was a bit low from running it for a while. Any one agree?
matthewd11 is offline
post #2 of 2 (permalink) Old 07-26-2008, 12:31 AM
SmokeyDiesel=HappyDiesel
Send a message via AIM to Hiflyer746 Send a message via Yahoo to Hiflyer746
Re: Boost pressures between cam sensors, there is a difference!
Yeah I think you should try it again when its a little cooler. It may not make a difference but then you will know for sure. Hey off topic a little. . . but what tire size are you running. . . are you stick or auto. . . and how is the turbo lag with that 71mm? Thanks
Timmy
I see in your sig. . . future BTS. . . so you are an auto.
2000 F-350 CC LB 4x4 6 spd diesel. Mods: Hmax headgaskets, valve springs and stage II injectors. Compounds, Terminated, Dp tuner, CPRX fuel system, oil bypass kit, Ceremetalic clutch, Procomp 6.5" lift, Motometal 951, 37" Nitto Mudgrapplers, Rhino lining, Autometer C2 Pyro, Boost and Oil Pressure, Coolingmist.
Hiflyer746 is offline
