??? powerstrokeshop overhaul kit ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-25-2008, 02:41 AM Thread Starter
sam's club member
Jet Fuel's Avatar
I bought a over haul kit from powerstroke shop and while I was assembling the motor I broke one of the piston rings, so I bought one from the stealership(actually it was a set for two pistons) and they were A little different.
So my question is, what did I put my motor together with? IH parts, aftermarket stuff? powerstroke shop says genuine Ford parts
I'm not looking to bash or burn anybody down I'm happy with the service and the price I got.I just want to know what I bought.
Jet Fuel is offline
post #2 of 19 (permalink) Old 07-25-2008, 02:51 AM
Re: ??? powerstrokeshop overhaul kit ???
The over haul kit should have Mahle pistons. Not sure what your stealership gave you.
TerminatorEngineering is offline
post #3 of 19 (permalink) Old 07-25-2008, 03:08 AM
i dunno why they would be different, but id first go to powerstrokeshop.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #4 of 19 (permalink) Old 07-25-2008, 04:08 AM
Laces Out
bigrpowr's Avatar
he means rings not pistons.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #5 of 19 (permalink) Old 07-25-2008, 04:33 AM
They are probably Clevite rings since Mahle and Clevite are part of the same corp. The rings might even be branded with either Mahle or Clevite names.
Unless the dealership is buying aftermarket stuff somewhere they should be the same rings you got with your rebuild kit. Might be from a different production run. How do they differ?
69W900A is offline
post #6 of 19 (permalink) Old 07-25-2008, 04:33 AM
Oooo, White Lightning !
Dieselboy's Avatar
You can buy rings from Powerstrokeshop
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #7 of 19 (permalink) Old 07-25-2008, 04:52 AM
I know, but he needs to make sure he has the proper rings.
post #8 of 19 (permalink) Old 07-25-2008, 01:46 PM
you want some of this?
smorris's Avatar
Got mine from powerstrokeshop and they are mahles. All the same as the oem were.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #9 of 19 (permalink) Old 07-25-2008, 02:09 PM
NorCalDiesel's Avatar
Don't mean to high jack this thread, but what machine work did you do to your block and heads for your rebuild. I am thinking of going down this road when needed and looked at this rebuild kit. Just curious
pat
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #10 of 19 (permalink) Old 07-25-2008, 10:06 PM Thread Starter
sam's club member
Jet Fuel's Avatar
pat
Not a high jack at all, I bought another basketcase motor that had a standard bore, the motor had been dusted and honed out just fine, had the crank polished and checked, the previous owner of the motor started the rebuild process and gave up after he spent 1200 bucks on having the heads rebuilt.
The only issue I had was the hard facing on one of the cam lobes was about gone and I couldn't find a cheap source for a new cam(powerstrokeshop wanted 500 bones for just a cam) I could have had the cam fixed for about 150 bucks but I just yarded out the old motor and and used the cam out of it, it checked out fine.
I'll get some pics of the rings, they are different, I just replaced the one I broke, I'm not too worried I just wanted to know what the deal was between the two.
Jet Fuel is offline
