ARP head stud torque - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-24-2008, 10:06 PM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
Just wanted to get some opinions from some of you knowledgable folk. I've asked on here before the torque steps to tightening head studs. Ive settled on 50,100,135. I have a box of ARP's here for a customer's truck, and they say only about 92ft-lbs...?
Stock
PowerstrokeJunkie is offline
post #2 of 6 (permalink) Old 07-24-2008, 10:25 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: ARP head stud torque
those are old pre DI intervention instructions.
Use what you posted above.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 6 (permalink) Old 07-24-2008, 10:46 PM Thread Starter
Thanks Dave
Stock
post #4 of 6 (permalink) Old 07-24-2008, 11:50 PM
racehauler's Avatar
If you do it without pulling the heads off you need to replace them one at a time and torque to stock head bolt spec. Then when the entire head has studs continue with the ARP torque procedure.
I torqued mine to 135 using the stock (120k mile) gaskets and have not had a single issue.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 6 (permalink) Old 07-25-2008, 02:42 AM
Layson's Avatar
I went ahead and torqued them up... then loosened them.. and torqued them again... Get them nice and stretched out...!
Layson is offline
post #6 of 6 (permalink) Old 07-25-2008, 03:04 AM
i used erics method and so far its worked great. 75+ psi on stock hg's.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
