Tuning and chip question/comment... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 75 (permalink) Old 07-24-2008, 03:11 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I have several chips from differant tuners, and while switching them the other day (now that I have the Scan gauge, THANKS JOEY!!!) I noticed something....
Take a look at "Chip A" and "Chip B" Note the ICP pressures and Duty cycles at idle...
One idles MUCH quieter, but on my truck seems to cause more ICP issues. I can tell that this one would make more power if I had oil, but as of now it doesnt.
The other idles a bit louder, but pulls harder and doesnt cause the ICP issues as easy...
Later on I would like to name the chips, but for now lets just go with Chip A and Chip B...
Joe
CSIPSD is offline
post #2 of 75 (permalink) Old 07-24-2008, 04:26 PM
Colorado PowerStroke Club
shayb's Avatar
Send a message via MSN to shayb
Re: Tuning and chip question/comment...
Joe,
Did you get both programs at the same time, thus telling the different tuners the same mods that you have and things that you wanted from the program or how you wanted it set up? Are they both econo, tow, dyno, race, what?
In other words, are they comparable programs?
Shay
Colorado Power Stroke Club & Colorado Diesel Truck Club Co-Founder
My pictures:
shayb is offline
post #3 of 75 (permalink) Old 07-24-2008, 04:46 PM
racehauler's Avatar
Hell I've got that all on one chip!
My "stockish power with b codes" tune runs about 600 ICP at idle. My tow tunes run about 700 to 750 at idle. I think the Extreme tune is around 700 as well. The stockish tune idles considerably quieter and is noticably quieter daily driving as well.
Your 942 psi at idle sounds like a but load of ICP to me though..........
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #4 of 75 (permalink) Old 07-24-2008, 06:47 PM Thread Starter
CSIPSD's Avatar
Both pictures are taken about 3 minutes apart, both on the most extream setting on the respective chips and both are set up for hybrids. One chip is about 3 months old, and the other about a week...
Nothing is strange about my truck other then the driver, stock oil, normal hybrids, BB turbo, HPO Crossover, fuel system...
Joe
CSIPSD is offline
post #5 of 75 (permalink) Old 07-24-2008, 06:53 PM
Banned
Send a message via Yahoo to blk99
I have to agree...
blk99 is offline
post #6 of 75 (permalink) Old 07-24-2008, 06:55 PM
The Fireman
big_stroker's Avatar
so the one with the hi ICP is witch chip... the one with the problem or the other one?
big_stroker is offline
post #7 of 75 (permalink) Old 07-24-2008, 06:57 PM Thread Starter
CSIPSD's Avatar
I want to reserve comment on that until a few more have giving there input, not trying to hang anyone, just thought it stange...
Like I said, one is much more powerful now, but the other obviously has the potential to be so with some more ICP pressures...
I have a theory on it but want to see what others have to say.
Joe
CSIPSD is offline
post #8 of 75 (permalink) Old 07-24-2008, 07:01 PM
The Fireman
im just trying to figure out if its "Chip A or B" that has the higher ICP and if thats the one the idles rought or quite i dont care for a tuners name
post #9 of 75 (permalink) Old 07-24-2008, 07:02 PM Thread Starter
CSIPSD's Avatar
...Again I want to see what others think before giving that out... Sorry...
Joe
CSIPSD is offline
post #10 of 75 (permalink) Old 07-24-2008, 07:21 PM
Village Idiot
southmike's Avatar
ok ..but my simple brain was expecting the numbers to be swapped..
seems like higher icp pressure should cycle less..
but the high pressure has the larger cycle &#37;.. am I blind , stupid or just don't know crap about icp.
southmike is offline
Closed Thread
