Big project this weekend any pointers? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-23-2008, 01:35 PM Thread Starter
fbilly420's Avatar
Well this weekend I am finally going to be installing my stealth DIY big oil with 4 lines and ITP reg return, intank mod and airflos fuel filters. Has anyone had problems moving the stock pump back on the frame rail about 3 feet? I am going to be running -6 line from the tank to the heads. Will be replaceing the entire fuel system accept for the pump.
Thanks in advance for your input.
Billy
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #2 of 15 (permalink) Old 07-23-2008, 01:43 PM
Re: Big project this weekend any pointers?
Billy
Just make sure you have extra fittings, hose and supplies before you start. It would suck to start Saturday, and need something else when the hose shop or parts house is closed.
99 F350 CCLB
skav is offline
post #3 of 15 (permalink) Old 07-23-2008, 01:53 PM Thread Starter
fbilly420's Avatar
Well the only thing I am not sure about are the fittings on the pump itself. Will the -6 hose push over the factory fittings on the pump? I am pretty sure I have all the hose and plenty of fittings.
workin on body
post #4 of 15 (permalink) Old 07-23-2008, 02:18 PM
<- Sums it up
strokin_early_99's Avatar
You say push over, I hope you are not using pushlock hose for the outputs.....The factory fittings are not AN, they are some kind of push lock fitting. The pump is #6ORB and the heads are #5ORB, get adaptors to go from those to #6JIC(same as AN).
It does suck to need a different fitting than came with the system and the shop is closed until monday. I really pisses you off with half the top end torn down.....
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #5 of 15 (permalink) Old 07-23-2008, 02:30 PM Thread Starter
fbilly420's Avatar
So I can replace the factory "push lock" fittings with a -6 ORB fitting on the pump itself on the inlet and outlet?
Should I not use push lok fittings from pump to the bowl delete block?
workin on body
post #6 of 15 (permalink) Old 07-23-2008, 02:34 PM
racehauler's Avatar
strokin was talking about the 4 line feed on your HPOP.
You may want a couple extra 45 and 90 degree -6 JIC hydraulic adaptors so that you can get your HPO hoses to lay how you want.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #7 of 15 (permalink) Old 07-23-2008, 02:39 PM Thread Starter
fbilly420's Avatar
OOOOOOOOOOOOOHHHHHHHHHHHHHHHHH
I am using 4 factory hpop lines. I was going to use some hydraulic hoses that I made at work, but found out I dont have the high temp Hyd. hose. So for now I am going to be using the factory ones until I get the right hose.
workin on body
post #8 of 15 (permalink) Old 07-23-2008, 02:55 PM
racehauler's Avatar
You may run into some slight issues with the factory lines if they are the 99 - 03 style with the "quick disconnect" style of hose ends. The 94 to 97 style hoses are standard -6 JIC hydraulic hose ends and are much easier to come up with 45 and 90 degree adapters for. I think that is the just of what strokin early 99 was trying to get accorss as well.
I'm not saying you can't do it with 4 of the 99 up hoses but you will have to be a little more crafty on you hose routing.
Eric
96 F-350 CC Dually
post #9 of 15 (permalink) Old 07-23-2008, 03:10 PM
Proud PSN Sponsor
Deputydog's Avatar
You'll wanna pull your turbo and pedistall off to make it easier to install the stealth.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #10 of 15 (permalink) Old 07-23-2008, 03:23 PM Thread Starter
fbilly420's Avatar
I was planning on pulling the turbo to replace the o rings. I hope it will make the RR install easier aswell.
I can get adapters. I will get a couple -5 ORB F to -5 ORB M 45 and 90's
workin on body
