DP F-5 installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 07-22-2008, 11:12 PM Thread Starter
< pissed off pumkin.
skylinedan's Avatar
Talking DP F-5 installed
Ok, I just had to do it and start a tread on putting it on. It went in fine , had to do a little land scaping to the black plastic holder for the pcm. I put the switch where they showed it, but anyone have thiers some where else ? I,m thinking next to the 4x4 selector switch. So far I made it out past the gate in front of the shop , gonna drive it home and report back in the morning. Hell I have,nt even been on the road and I,m grinning, .
Tunes...
no start
stock
high idle 1100 rpm,s
60 tow
80 tow
80 e
120 race
140 extreem
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #2 of 16 (permalink) Old 07-23-2008, 12:32 AM
Re: DP F-5 installed
I can't be of any help, as I got the gauge switch and put it on a 2-pod A-pillar mount with my Aeroforce Scangauge.
But I'm still waiting for my BTS valvebody to arrive so I can hook up the chip to the PCM...
bobbarry is offline
post #3 of 16 (permalink) Old 07-23-2008, 12:38 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I had the gauge mount, then switched to the pod holder...
Joe
CSIPSD is offline
post #4 of 16 (permalink) Old 07-23-2008, 02:04 AM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
How did you run your wire to the back of the switch Joe?
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #5 of 16 (permalink) Old 07-23-2008, 11:44 AM Thread Starter
skylinedan's Avatar
Talking Re: DP F-5 installed
Well I went out and drove around last night, all I can say is this things is just stupid fast compared to the Sct. I have to get use to the pedle being so sensitive, especialy the high end tunes. Oh and for those of you who say you can,t feel a difference between the 80e and 120r or 140ex to bad. You can feel a definate difference between them, I think we talk about horse power a lot when it comes to tuninng, but what about the torque gains. So yes, I have a bad case of perma grin, .
Dan
post #6 of 16 (permalink) Old 07-23-2008, 12:01 PM
The Fireman
big_stroker's Avatar
Why ??? you can run the chip with out the valvebody.
big_stroker is offline
post #7 of 16 (permalink) Old 07-23-2008, 01:29 PM
OBS junkie
Cat_Rebel's Avatar
Dan
Awesome to hear Dan, I knew you would enjoy it ALOT! Running around unloaded or with light loads you'll find yourself in the higher tunes more often.
Sure you can, but if he ordered it setup for thye BTS valve body might as well wait. I'm not a big fan of the way these trucks shift with the chip & no shift kit.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 16 (permalink) Old 07-23-2008, 01:36 PM
Sleep well my brothers
yamt03's Avatar
Welcome to the perma grin club I have mine mounted like the instructions say but I have been thinking about getting the ont that Joe has.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #9 of 16 (permalink) Old 07-23-2008, 02:43 PM
I asked Jody to tune it to work with the valvebody; I've only seen bad reports of those whose tunes were mated to the BTS valvebody but who were impatient and put the chip in before the valvebody was installed.
That's fine, though; I installed the EGT probe and Gauge switcher yesterday, and work is occupying me all day today, so when it all comes in, I'll be rolling with tunes in a day. :)
bobbarry is offline
post #10 of 16 (permalink) Old 07-23-2008, 04:47 PM Thread Starter
skylinedan's Avatar
I,m running mine with a stock trans till I get the tugger kit in the new one I have here, just haven,t had the time to do it. Now that I have the F-5 I,m gonna have to make it a point to find the time, . Brian drove it today to get lunch, he loves it over the SCT . I like the 140 a lot, the peddle is so touchy you have to be carefull you don,t run someone over when the light turns green though, . Yes, its cool being in the perma grin club. I have to get paul to take it for a spin, see how he likes it compared to his 06 with my old SCT.
Dan
