Performance Unsatisfactory - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 51 (permalink) Old 07-22-2008, 09:00 AM Thread Starter
Got my truck back to work. I definatly do not have the performance that I had hoped for. I have towed 600miles with it since yesterday. I can not seem to clean up the fuel, I get some form of black smoke in every tune. In stock tune I have a little smoke and higher egt's than normal. I can hit 1200* in stock easy. 40T tune I have fair amount of smoke, and had to either down shift or getout due egts. It only worsen in the higher hp tunes. I can acheive 28psi boost easy, turbo lags just like the stocker. I have not been able to find any boost or exhuast leaks. I don't know what kind of problem I have. I think the trucked towed better before I did the change. The truck won't even lite the tires with 5psi boost launch in 140 tune. Going today to find out how much pressure the hpop are maintaining.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #2 of 51 (permalink) Old 07-22-2008, 12:04 PM
Re: Performance Unsatisfactory
What changes did you make?
TXstroker01 is offline
post #3 of 51 (permalink) Old 07-22-2008, 01:37 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
What all did you change?
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #4 of 51 (permalink) Old 07-22-2008, 01:44 PM
HP Junky
Ummm...if your stock turbo was laggy. You've got an underlying problem
RockinJW is offline
post #5 of 51 (permalink) Old 07-22-2008, 03:36 PM
<- Sums it up
strokin_early_99's Avatar
TN BB/high flow outlet with big oil and good tuning? You have problems somewhere......It should not run hot. Check for boost leaks or exhaust leaks.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #6 of 51 (permalink) Old 07-22-2008, 03:37 PM Thread Starter
I meant from a deadstop the turbo is lagging. I install Regulated return, BTS HPOP, TN BB, Hiflow outlet, Non EBPV pedistal, DI Bellowed up-pipes, New Tunes from DP.
Torque37 is offline
post #7 of 51 (permalink) Old 07-22-2008, 03:43 PM
Did you run that combo with the stock turbo or are you trying to compare the stock turbo without all the other stuff?
69W900A is offline
post #8 of 51 (permalink) Old 07-22-2008, 04:05 PM
DarkShadowDiesel's Avatar
check your tunes - i had similar problems when i got retuned once. try pulling the chip
2002 F250
DarkShadowDiesel is offline
post #9 of 51 (permalink) Old 07-22-2008, 04:32 PM
imelmo's Avatar
The discussion that was here previously has been moved to Smack so the op can continue on with his thread as intended.
imelmo is offline
post #10 of 51 (permalink) Old 07-22-2008, 08:00 PM Thread Starter
I just did everything I mentioned at one time. I was using the stock turbo and dp tuner before. What about fuel pressure, what kind of effects does it have. I have the regulator set 57psi.
Torque37 is offline
