PCM Code help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-05-2007, 12:10 AM Thread Starter
Deputydog's Avatar
PCM Code help
Well the code I keep getting while under full throttle is P0238.. Can anyone direct me to what this means or how to fix it.. I have a boost fooler thing but may need to turn it up..
Deputydog is offline
post #2 of 5 (permalink) Old 09-05-2007, 12:19 AM
<----Colin Banks
mattymx's Avatar
Re: PCM Code help
P0238 Turbo Boost Sensor A Circuit High Input
Sounds like the controller needs to be opened up a bit.
mattymx is offline
post #3 of 5 (permalink) Old 09-05-2007, 12:26 AM
Re: PCM Code help
For future reference you can search for the codes here. If they dont show up just be patient, more will be added.
https://www.powerstrokenation.com/forums/faq.php
gregrob is offline
post #4 of 5 (permalink) Old 09-05-2007, 12:39 AM Thread Starter
Deputydog's Avatar
Re: PCM Code help
Ok thanks for the quick replies and the link
post #5 of 5 (permalink) Old 09-05-2007, 12:45 AM
Proud PSN Sponsor!
Strictly Diesel's Avatar
Re: PCM Code help
P0238 is an ELECTRICAL code. P1249 is an "Overboost" code.
P0238 is either "Damaged MAP Sensor", "MAP Signal Circuit Short to Power or VREF" or "Faulty PCM".
If you have a good scantool (like AutoEnginuity or other) that can run KOEO tests, do the following:
1. Clear Codes
2. Disconnect MAP Sensor Electrical Connector
3. Key On / Engine Off
4. Run KOEO On Demand Self Test
If the P0238 returns, the problem is in the wiring or PCM. If no code returns, replace the MAP sensor.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
