Water/Meth Injection - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 07-17-2008, 12:39 AM Thread Starter
Military Member
drtydzel's Avatar
Garage
Send a message via Yahoo to drtydzel
hey I know this is not a 7.3L question but maybe you can help I am currently in Japan and have a 2.5L intercooled turbo diesel it is in a 1989 Mitsubishi Pajero and I want to use a windshield washer pump and tank for a Water Meth Injection kit the truck was only a 1000 dollars so im really not worried about killing it. I have already made a exhaust and intake for it i also turned the boost up from the factory 7PSI to 17PSI but my EGT's are kinda iffy some times at cruising speeds there 600-800 depending on the hills and stuff but when pulling hard on steep long grades it hits around 1000-1100 when being worked really hard so I want to make and install a water meth kit to try to help control this any info on this topic. thanks and as always have a nice day
In the market for a 99-02 F350
drtydzel is offline
post #2 of 13 (permalink) Old 07-17-2008, 12:41 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Water/Meth Injection
The kit was $1000???
Joe
CSIPSD is offline
post #3 of 13 (permalink) Old 07-17-2008, 12:43 AM
Praying for BOOST!
lords88's Avatar
I think he said the truck was only $1000 not the kit. Atleast I hope that's what he said.
2002 F250 super cab w/long bed :thumb:rapid flow intake, zoodad mod, wicked wheel, bellowed uppipes, Custom Wildman Tunes! 4'' exhaust, 5'' rolled chrome tip, banks transcommand, dual trans coolers, cooling mist inject, wheels, tires, tinted windows, and all the chrome accessories I can stack on it! :nod:
lords88 is offline
post #4 of 13 (permalink) Old 07-17-2008, 01:08 AM
POWERSTROKER's Avatar
I dunno if the little pump can supply enough pressure or water for that to work properly
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #5 of 13 (permalink) Old 07-17-2008, 01:12 AM
Banned
Well, with that crappy little pump you can't try to run the flow post turbo because you would likely just get a bunch of air bubbles in your washer tank when the boost backfed the tank right through the little pump. And even if it did muster up more than 17lbs, it most likely wouldn't be enough for any reasonable flow rate nor "spray"
And you can't spray it pre charger because that crappy little pump isn't going to atomize well enough to keep your compressor wheel in one piece.
Might as well get a shurflow pump or similar.
Charles is offline
post #6 of 13 (permalink) Old 07-17-2008, 02:06 AM Thread Starter
Military Member
drtydzel's Avatar
Garage
first off yes the truck was 1000
so basically i just need to order a kit from snow or someone to do this with any sort of positive results OR would propane be a better choice let me know what you think out there and thanks for the advice so far and as always have a nice day
drtydzel is offline
post #7 of 13 (permalink) Old 07-17-2008, 03:30 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
runnnn oonnnnnn sentenceeeee
Stock
PowerstrokeJunkie is offline
post #8 of 13 (permalink) Old 07-17-2008, 03:33 AM
Drink til she's cute
Thuglike's Avatar
Damn...you played the run on card!!!!
Gutsy!!!!!!
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #9 of 13 (permalink) Old 07-17-2008, 05:44 PM
CSIPSD's Avatar
www.ktperformance.net...
Joe
CSIPSD is offline
post #10 of 13 (permalink) Old 07-17-2008, 05:45 PM
CSIPSD's Avatar
http://stores.ktperformance.net/Detail.bok?no=487
Good cheap kit with everything you need!
Joe
CSIPSD is offline
