Garrett 38R - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 134 (permalink) Old 07-16-2008, 05:01 PM Thread Starter
Busy Busy
Marty's Avatar
Garrett 38R
Well I just got it. It's got some shaft play, side to side... it goes from being almost 2 mm away from the housing to just under a mm. Seem normal? I've got a video and pictures.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 134 (permalink) Old 07-16-2008, 05:32 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Garrett 38R
For comparison here is the TN when I bought it
Elkton, Maryland
Marty is offline
post #3 of 134 (permalink) Old 07-16-2008, 05:51 PM
<-- it's like that
Re: Garrett 38R
For the 38R, they typically have shaft play without any oil in them (the bearings float on oil). If there is enough play to allow the wheel to contact the housing, then you have problems. Also, there should be no in/out play.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #4 of 134 (permalink) Old 07-16-2008, 05:59 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Garrett 38R
That's exactly what I thought (read it somewhere). It does not come in contact with the housing and there is no in and out play.
Elkton, Maryland
Marty is offline
post #5 of 134 (permalink) Old 07-16-2008, 06:07 PM
<-- it's like that
Re: Garrett 38R
Then you should be fine. Have fun installing.
Curtis
2002 F-250 PSD
Pocket is offline
post #6 of 134 (permalink) Old 07-16-2008, 06:09 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Garrett 38R
Better pull more then 36 psi
Elkton, Maryland
Marty is offline
post #7 of 134 (permalink) Old 07-16-2008, 07:33 PM
fueled by Colecovision
golfer's Avatar
Garage
Re: Garrett 38R
...looking forward to seeing the back to back comparison...
golfer is offline
post #8 of 134 (permalink) Old 07-16-2008, 08:19 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Garrett 38R
Unfortunately it won't be back to back to back like originally planned since my TN BB ate itself.
However I ran back to back to back 13.7's @ 97 mph on position #4 with the TN in 80 some degree weather. With 1/2 tank, back seat, spare, tailgate on. So I plan to run with 1/4 tank this weekend and will have the seat, spare and tailgate on for that run since the weather looks to be within 10 degree's.
Elkton, Maryland
Marty is offline
post #9 of 134 (permalink) Old 07-16-2008, 08:24 PM
<<<<< Next Generation
boggerr's Avatar
Re: Garrett 38R
Marty, that play is normal. Better than 36 be ready for more than 40. I'm hitting 32 with stock injectors
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #10 of 134 (permalink) Old 07-16-2008, 09:43 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Garrett 38R
Oil... duh. I think I have told others in the past that it's normal with the 38R until you get oil in it.
I hope to see 40+... finally start seeing what this baby can do!
Elkton, Maryland
Marty is offline
