DIY INJECTOR KITS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 07-15-2008, 10:01 PM Thread Starter
DIY INJECTOR KITS
i was just wondering if anyone has tried out the diy kits from rosewood diesel and if so how you like them kinda thinking about buying a set but not sure yet if you have any info on them please let me know thanks
strokensmoke1693 is offline
post #2 of 25 (permalink) Old 07-15-2008, 10:08 PM
Busy Busy
Marty's Avatar
Re: DIY INJECTOR KITS
What set do you plan on buying? He has several.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 25 (permalink) Old 07-15-2008, 10:12 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
I have the DIY Stage 2C's on my truck, I didnt do the work, i had him put them together because that's something very easy to mess up.
Stock
PowerstrokeJunkie is offline
post #4 of 25 (permalink) Old 07-15-2008, 10:17 PM
I did, despite everyone at the time telling me not too.
They've been working great so far. Never fail contribution, idle as good as any other single shot truck I've been around, and make just the right amount of power for me.
What year is your truck?
gregrob is offline
post #5 of 25 (permalink) Old 07-15-2008, 10:47 PM
hendershot's Avatar
I ordered a set from him and built them my self and i was pleased with the out come. It runs alot better then it did before.
hendershot is offline
post #6 of 25 (permalink) Old 07-15-2008, 11:15 PM
Military Member
drtydzel's Avatar
Garage
Send a message via Yahoo to drtydzel
been looking into a set for myself if you get them do a good write up on them how hard are they to build any and all info on this will be put to good use by someone thanks and as always have a nice day
In the market for a 99-02 F350
drtydzel is offline
post #7 of 25 (permalink) Old 07-15-2008, 11:19 PM
Hendershot, impressive avatar pic. I'm assuming you are running the hybrids or "larger" with a bigger framed turbo?
Stock
post #8 of 25 (permalink) Old 07-16-2008, 02:46 AM
urbanwheeler's Avatar
i got the 230cc hydrid set, havent gotten them installed yet but they come with a cd that has everything you will need on it, pics and text.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #9 of 25 (permalink) Old 07-16-2008, 02:55 AM
i have seen more people have success with the DIY injector kits than have problems with them. I think the only problems i remember some having were a bad set of injector o-rings with the older kits, that has been addressed now.
Diezel Dawg is offline
post #10 of 25 (permalink) Old 07-16-2008, 03:15 AM
NorCalDiesel's Avatar
I think the key to getting a good rebuild/upgrade with his DIY kit is based on what you start with. If you start with injectors that are not within tolerances or need work just to get them ready for the DIY install then you will not like the outcome. Unless of course you repair or replace the out of spec injectors. Basically you can't polish a turd.
I have never rebuilt an Injector before much less pulled one apart. But I have just finished checking tolerances and specs on my stockers to make sure they can be successfully upgraded. I am going to do the rebuild tomorrow.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
