ww install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 07-15-2008, 05:23 AM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
ww install
can you install a ww w/o pullin the turbo? thanks
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 17 (permalink) Old 07-15-2008, 05:28 AM
bigd4me2's Avatar
Re: ww install
yes. but for a 99.5 its not the right way to go, but in you sig looks like you are installing it on a 96?
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 17 (permalink) Old 07-15-2008, 05:46 AM
Layson's Avatar
Re: ww install
Yes you can... but that turbo is not to hard to pull either...
Layson is offline
post #4 of 17 (permalink) Old 07-15-2008, 11:59 AM Thread Starter
Crazy Talk
Re: ww install
it for my dads 2000, it surges bad towin. would this fix it
post #5 of 17 (permalink) Old 07-15-2008, 12:06 PM
POWERSTROKER's Avatar
Re: ww install
WW might fix it or it might not, you will have to try it and see.
A for sure fix for surge is the ATS ported housing.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #6 of 17 (permalink) Old 07-15-2008, 01:01 PM
The Fireman
big_stroker's Avatar
Re: ww install
i installed mine with out taking the turbo off... it helped with surge but didnt fix it completely i still have it in my hi setting on my chip
big_stroker is offline
post #7 of 17 (permalink) Old 07-15-2008, 01:59 PM
Layson's Avatar
Re: ww install
Here is an oldy but goody...
http://www.blackclouddiesel.com/Tech...on%20Guide.pdf
Layson is offline
post #8 of 17 (permalink) Old 07-15-2008, 05:27 PM Thread Starter
Crazy Talk
Re: ww install
ok cool thanks guys, i am hopin it might cause my grandads early 99 never surges towin w/ a chip or ever for that matter
post #9 of 17 (permalink) Old 07-15-2008, 05:50 PM
Busy Busy
Marty's Avatar
Re: ww install
Early 99 = smaller injectors = less power.
I have a video on how to install the WW in the cab, let me go get it.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #10 of 17 (permalink) Old 07-15-2008, 05:52 PM
OBS junkie
Cat_Rebel's Avatar
Re: ww install
Isn't that hard to pull the turbo off. I'd just pull it out instead of laying across the engine trying to install it.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
