Conversion from 2wd to 4wd? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-14-2008, 11:21 PM Thread Starter
spb_2006's Avatar
Ive got a 2000 7.3 2wd, i dont want to trade it but...i was wondering how expensive, complicated, and how long it would take to convert from a 2wd to 4wd, as an at home project? I was wondering if anyone had done this ans how it went? Im tired of doing nothing but spin my tires!
spb_2006 is offline
post #2 of 15 (permalink) Old 07-15-2008, 12:01 AM
urbanwheeler's Avatar
Re: Conversion from 2wd to 4wd?
what do you do with the truck?
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #3 of 15 (permalink) Old 07-15-2008, 12:34 AM
OBS junkie
Cat_Rebel's Avatar
It can be done, all the holes are there. Your best bet is to find a wreaked 02-04 F250-F350 & get the front axle (Dana 60 in those years) transfer case (manual case over electric is easier to swap & more reliable) driveshafts, all the steering components & leaf springs. If possiable get the tranny as well since you will either have to swap in a 4x4 tranny to bolt up to the T case or change out the tail of your 2wd tranny.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 15 (permalink) Old 07-15-2008, 12:58 AM
Power Stroke Psychiatrist
Power Smoker's Avatar
I did one once on an '01 X. It was an electrical nightmare. It was all bolt on as far as the axle, t-case, 4X trans, drivelines, front axle etc. sourced from a rolled excursion. The problem was the electrical for the 4X4. If you just use a manual floor shifter setup and don't worry about a 4X4 light coming on on the dash it should be all mechanical bolt-on with possible minimal drilling for brackets. the frames are the same, just check for bolt holes to see what you'll have to do. also, make sure the gear ratios are the same in the axles you use. You can also do just the front axle first, and later do the trans/t-case swap, or the other way around if it's too much of a job to do at once.
Wayne Yates
Power Smoker is offline
post #5 of 15 (permalink) Old 07-15-2008, 05:31 AM Thread Starter
spb_2006's Avatar
Well, i pull a trailer right now ever once in a while but its not real heavy. Id like to mod it some but all i do is spin even with just the chip, intake and stacks...its also a manual. I dont know if that matters or not...will i need to lift it or will the new suspension in the front be enough...I think i would probably not worry about the light coming on.
spb_2006 is offline
post #6 of 15 (permalink) Old 07-15-2008, 07:33 AM
All done now
Arisley's Avatar
Find a 4X4 you like. Sell your 2WD buy the 4X4 and be happy. With todays prices it should even be kida painless. Of course take off any nice arts you dont want to give away.
Arisley is offline
post #7 of 15 (permalink) Old 07-15-2008, 07:37 AM
OBS junkie
Cat_Rebel's Avatar
Originally Posted by spb_2006 View Post
will i need to lift it or will the new suspension in the front be enough....
When you get the springs for the axle it will have everything you need. More lift is up to you. In the back a 2wd is the same height as a 4x4.
RIP Will Iott
post #8 of 15 (permalink) Old 07-15-2008, 07:01 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
If you buy a lift kit then don't buy the leaf springs off of the donor truck.
I would try to update to the 05+ suspension if I were gonna do it from scratch... but that's just my $.02....
Jeret
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #9 of 15 (permalink) Old 07-15-2008, 07:06 PM
OBS junkie
Cat_Rebel's Avatar
Jeret
It wouldn't be "bolt together" but you could get it to work.
RIP Will Iott
post #10 of 15 (permalink) Old 07-15-2008, 07:43 PM
Ricky Bobby
JSlack's Avatar
id just buy a 4x...they are going for CHEAP round here...wish i woulda waited 6 months to buy my truck...coulda saved 5-7G's
JSlack is offline
