head stud retorque - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 07-14-2008, 01:44 AM Thread Starter
lets roll
thunderstroke's Avatar
head stud retorque
Want to do head studs in my engine before running bigger turbo (never broke anything or broke down yet, and like to bug the s**t out my dodge buddies about that). So is best to retorque studs or are there some that you don't and if you do, do you have to remove your injectors for access?
2000 f-250, dp f-5, ddp 120hp single shots, mbrp turbo back, itp boost fooler, itp pre-pump kit, banks billet torque converter, coolingmist cmgs
thunderstroke is offline
post #2 of 17 (permalink) Old 07-14-2008, 01:49 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: head stud retorque
You don't have to but if you wanted to do it anyway you don't have to remove the injectors, just rotate them enough to get to the nut under the injector.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 17 (permalink) Old 07-14-2008, 02:05 AM Thread Starter
lets roll
thanks, never thought of rotating the injectors for access.
post #4 of 17 (permalink) Old 07-14-2008, 02:10 AM
You only need to retorque fire-rings, stock HG's don't need a retorque.
69W900A is offline
post #5 of 17 (permalink) Old 07-14-2008, 03:57 AM
Layson's Avatar
Do you just twist them around? Does that damage the o rings?
thanks...
Layson is offline
post #6 of 17 (permalink) Old 07-14-2008, 04:54 AM
Laces Out
bigrpowr's Avatar
i think for security a "hot" retorque couldnt hurt, could it?
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #7 of 17 (permalink) Old 07-14-2008, 04:57 AM
Mr. Bob's Avatar
What are you guys torquing head studs too??? I have heard so many different numbers
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #8 of 17 (permalink) Old 07-14-2008, 05:18 AM
For stock HG's? It won't hurt, but due to the design of the stock HG it won't compress anymore than it does on the initial torque.
Fire rings are a different story.
69W900A is offline
post #9 of 17 (permalink) Old 07-14-2008, 05:26 AM
Laces Out
bigrpowr's Avatar
got ya..i did a hot retorque on the fire rings. lasted almost 2 years.
bigrpowr is offline
post #10 of 17 (permalink) Old 07-14-2008, 05:30 AM
On firerings I've had to retorque 5 or 6 times on some applications. Fire rings I just keep retorqueing until I don't get anymore movement.
69W900A is offline
