Same old question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 07-13-2008, 06:04 PM Thread Starter
treyloco's Avatar
Same old question
Muffler or no muffler is there any benefits?
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #2 of 16 (permalink) Old 07-13-2008, 06:07 PM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Re: Same old question
sounds better. Probably depend on if you are talking about the stock muffler or aftermarket. Aftermarket will flow better. Thats about all I know. I did away with it, sounds good.
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #3 of 16 (permalink) Old 07-13-2008, 06:20 PM
2nd class citizen
1snotrocket's Avatar
no muffler sound better.didn't really notice any performance increase by removing it.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #4 of 16 (permalink) Old 07-13-2008, 06:51 PM
POWERSTROKER's Avatar
the stock muffler seems pretty restrictive to me, I say remove it, and it will prolly lower your EGT's a bit to.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #5 of 16 (permalink) Old 07-14-2008, 03:15 AM
bigd4me2's Avatar
I'll be the oddball, turbo is too loud for me with straight pipe, but i have a regular cab chassis with exit in front of rear tire. i have a magnaflow straight thru, works well for me. no restriction.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #6 of 16 (permalink) Old 07-14-2008, 03:19 AM
You'll lower the EGTs, it'll help as you start to build more power but past stock you'd want better pipes anyway so a replacement system is in order.
69W900A is offline
post #7 of 16 (permalink) Old 07-14-2008, 03:56 AM
Reg. cab with stacks. Rear window open all the time. Might be because I could "possibly" be younger.
You know what they say "If it's to loud, your to old." lol
post #8 of 16 (permalink) Old 07-14-2008, 04:26 AM Thread Starter
treyloco's Avatar
I have a 4" stainless system right now, but I have heard from some that you can loose power taking off the muffler. ALso is it that much louder w/out the muffler.
AFE Stage 2
DI 6 position
treyloco is offline
post #9 of 16 (permalink) Old 07-14-2008, 04:39 AM
OBS junkie
Cat_Rebel's Avatar
Take off the muffler.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 16 (permalink) Old 07-14-2008, 05:13 AM
bigd4me2's Avatar
ya, thats what they say "kid"
but i do sometimes drive my truck for about 20 hours straight, that noise gets old, like me! theres nothing wrong with a straight thru magnaflow.
bigd4me2 is offline
