help FAST..electric fuel problems(QUAD FEED) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-12-2008, 09:29 PM Thread Starter
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
well i just got my electric fuel system and Stealth DIY pumps installed....
rolled the key to prime the system and check for leaks, pump kicked on like it should for about 30seconds then the return line started jumping and making this banging noise....
cycled the key and it did this imediately....FP is around 60 psi(but the needle is jumping in sequence with the return line)
started the truck and it seems to idle great...but the issue is still present...
HELP!
http://s169.photobucket.com/albums/u...9-17-07001.flv
http://s169.photobucket.com/albums/u...9-17-07002.flv
CCLB with some stuff done .....
BigRed97 is offline
post #2 of 19 (permalink) Old 07-12-2008, 09:40 PM
urbanwheeler's Avatar
Re: help FAST..electric fuel problems(QUAD FEED)
what size is the fuel return? is it possible your regulator is acting up? have you tried changing you fuel psi?
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #3 of 19 (permalink) Old 07-12-2008, 09:59 PM Thread Starter
The Oracle
BigRed97's Avatar
return line is -6 from the regulator then mated to the stock line off the selector valve
i tried the FP any where from 90-50psi and it still did it
BigRed97 is offline
post #4 of 19 (permalink) Old 07-12-2008, 10:15 PM
Banned
It's just working the air out. It'll stop.
Charles is offline
post #5 of 19 (permalink) Old 07-12-2008, 10:57 PM Thread Starter
The Oracle
BigRed97's Avatar
great thats what i was hoping to hear
thanks Charles
BigRed97 is offline
post #6 of 19 (permalink) Old 07-13-2008, 01:23 AM
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
I agree I have seen some of our JD tractors do the same thing when we change out a busted hdy line and get air in the system.
lildevil02 is offline
post #7 of 19 (permalink) Old 07-13-2008, 02:55 AM
all my air came out within a few minutes.
[SIGPIC][/SIGPIC]
post #8 of 19 (permalink) Old 07-13-2008, 03:00 AM
Banned
Mine did machine gun fire out the return line for a minute or so, and then it was completely cleared up before I ever fired it.
I just cycled the key until it cleared out.
Charles is offline
post #9 of 19 (permalink) Old 07-13-2008, 03:45 AM
Soon to be a 6.4
lildevil02's Avatar
Is it possible for the pump or a fitting to be sucking in air?
post #10 of 19 (permalink) Old 07-13-2008, 03:52 AM Thread Starter
The Oracle
BigRed97's Avatar
well i drove it for a few hours (hard) and its somewhat better, but it still does it....
BigRed97 is offline
