TN BB Disapointment - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 211 (permalink) Old 07-12-2008, 04:43 AM Thread Starter
NEVRNF's Avatar
Unhappy TN BB Disapointment
Recently switched to a TN BB with the intentions of doing twins in the near future. I have been running the truck for the last week and i am very disapointed in the performance of this turbo. Even my laggy H2e worked better than this. I have checked for leakes in both the hot side and cold side and there are none. Today driving on the highway @ 65mph i had NO boost showing on the gauge and EGT were 1k. The old H2e at least made 3-4 psi in the same situation and EGT were 700's.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #2 of 211 (permalink) Old 07-12-2008, 04:46 AM
Don't EFN worry about it
Aljay's Avatar
Re: TN BB Disapointment
GARRETT ...............!
Tuned by T Wildman
Aljay is offline
post #3 of 211 (permalink) Old 07-12-2008, 04:47 AM
Orezona's Avatar
Hey Joe! Hold back man, hold back!
Orezona is offline
post #4 of 211 (permalink) Old 07-12-2008, 04:48 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Something must be wrong with the install. Triple check everything before you go blaming the turbo when it could quite possibly just be the installer.
Stock
PowerstrokeJunkie is offline
post #5 of 211 (permalink) Old 07-12-2008, 04:51 AM
Orezona's Avatar
Maybe the back band-clamp?
Orezona is offline
post #6 of 211 (permalink) Old 07-12-2008, 04:52 AM Thread Starter
NEVRNF's Avatar
i have checked everything, Twice. I even took it off and reinstalled everything thinking the back clamp did not seat correctly. It has nothing to do with the installer.
Tony
The truck
should have built
FOR SALE
NEVRNF is offline
post #7 of 211 (permalink) Old 07-12-2008, 04:59 AM
Kip
Kip's Avatar
oh hell its done been started wait till Joe sees this
2005 Chevy Duramax (thats right I have a chevy and am on PSN. I use to have a PSD and I like this place.
THE SAINTS still suck GO COWBOYS!!!!
Kip is offline
post #8 of 211 (permalink) Old 07-12-2008, 05:01 AM
DarkShadowDiesel's Avatar
that sucks. call them and have them send you a new one if all the other probs are diagnosed!
hopefully there are no boost/exhaust leaks... sounds like you got it though.
if there are no probs, it's a bad unit. i can tell you mine does not perform like that. hopefully this doesn't turn into a pissing match, there CS is good and keep us posted on what happens.
2002 F250
DarkShadowDiesel is offline
post #9 of 211 (permalink) Old 07-12-2008, 05:07 AM
Orezona's Avatar
OP, where did you buy your turbo from?
Orezona is offline
post #10 of 211 (permalink) Old 07-12-2008, 05:10 AM Thread Starter
NEVRNF's Avatar
I have pulled my hair out over this. i had as much as 25psi in the Dieselsite style leak tester and no leaks in the system. I also checked again and there is no soot anywhere.
Tony
The truck
should have built
FOR SALE
NEVRNF is offline
Closed Thread
