EDM nozzles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 07-11-2008, 08:17 PM Thread Starter
EDM nozzles
What size EDM nozzle would it take to get 600 hp with a full built motor and plenty of air with B code sticks? Could you use something like a .008 or would you need larger?
Thanks,
[SIGPIC][/SIGPIC]01' F-350 CC,LB,SRW,4x4,BTS,Stealth Oil,Live DP Tuning,ITP fuel,530's,BB turbo w/1.15,4"turboback,DIY Tymar,Autometer's, & PMR's 449 hp/ 940 torque in 80 ecno tune @ Gams
urbandiesel is offline
post #2 of 33 (permalink) Old 07-11-2008, 08:53 PM
Slated4Greatness's Avatar
Re: EDM nozzles
I would say many factors exist to determine this but I would say larger than .008 would be needed. I was at .009 and was at <500HP (Stage III hybrids not B codes). The SHO's are in the .012 range arent' they?
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #3 of 33 (permalink) Old 07-11-2008, 09:32 PM
Sponsor
Re: EDM nozzles
I would put 200&#37; factory enlarged nozzles on them. They are just shy of .012". Luke Cline has a set running on his. I'm sure he can tell how he likes running them. But we've seen real good results with the injectors we've installed them on.
615-962-8291
Cass is offline
post #4 of 33 (permalink) Old 07-11-2008, 09:49 PM
Laces Out
bigrpowr's Avatar
Re: EDM nozzles
Originally Posted by Cass View Post
I would put 200% factory enlarged nozzles on them. They are just shy of .012". Luke Cline has a set running on his. I'm sure he can tell how he likes running them. But we've seen real good results with the injectors we've installed them on.
i know .012's are good for 700+... so .010 would prolly do 600 no problem.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #5 of 33 (permalink) Old 07-11-2008, 10:01 PM
Tim @ P.I.S.'s Avatar
Re: EDM nozzles
Stock BD's switched over to 100&#37; nozzles with a modded h2e, BTS oil and DD DP tunes did 502 about a year or so ago. 200's on a set of hybrids are currently in the low 12's.
Tim @ P.I.S. is offline
post #6 of 33 (permalink) Old 07-11-2008, 10:27 PM
Banned
Re: EDM nozzles
I did 533 uncorrected with 20% over EH nozzles. So 600 should be a breeze with 200% EDM's.
Course so should 700, 800, 900....
Charles is offline
post #7 of 33 (permalink) Old 07-11-2008, 11:47 PM
Re: EDM nozzles
What would be the max H.P. for a set of Beans-Cass hybrids with .008 nozzles?
96 F350 4x4 35" BFG Mud T/A Weld SS II. Chip,Intake,4" Exhaust. Isspro Pyro,Trans,Boost. BTS. Hybrids,Fuel System,IDM,and Modded H2E from Bean. R&R Rods. Girdle and Push Rods from WOP.
phoneman is offline
post #8 of 33 (permalink) Old 07-11-2008, 11:59 PM
Laces Out
bigrpowr's Avatar
Re: EDM nozzles
if they are edm prolly around 475.
bigrpowr is offline
post #9 of 33 (permalink) Old 07-12-2008, 01:44 AM
<- Sums it up
strokin_early_99's Avatar
Re: EDM nozzles
100% over and you made 502.....I run stock B codes with .0065" nozzles and am at 488. What you are saying is I need another 80% or so to make up 14hp?
Something sound odd, I run a modded H2E as well.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #10 of 33 (permalink) Old 07-12-2008, 01:56 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: EDM nozzles
About what size would that make your nozzles?
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
