Turbo Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-03-2007, 03:11 AM Thread Starter
Deputydog's Avatar
Turbo Question
I have a new Turbonetics. When I romp on it, it boosts to about 25-27lbs pretty quick, but levels off there. Then I get a check engine light that comes on. After I back off the accelerator, the check engine light goes off within about 30 seconds to about 1 minute.. I have tried this with both the wastegate line (red line) connected and disconnected but it does the same thing either way. I think the TN should be good for well over 30lbs.. Any idears?
Deputydog is offline
post #2 of 18 (permalink) Old 09-03-2007, 03:13 AM
Lurker...
Fever's Avatar
Re: Turbo Question
do you have a MAP fooler?
2003 F-350 Super Duty
Fever is offline
post #3 of 18 (permalink) Old 09-03-2007, 03:20 AM Thread Starter
Deputydog's Avatar
Re: Turbo Question
Yes I doo.. It has an adjustable dial on it, but it shouldn't matter I don't think since it seems to do it weather the wastegate line is connected or not..
post #4 of 18 (permalink) Old 09-03-2007, 03:25 AM
you want some of this?
smorris's Avatar
Re: Turbo Question
The wastegate has nothing to do with the boostfooler. All it does is keep the map sensor from seeing more than about 20-21 pounds of boost. If it "sees" more than 26 psi it will make the SES light come on till it drops below there for about a minute or so. Also , I think it will defuel , and keep you from making more boost/ hp. So, sounds like maybe you need to adjust the regulator down some and try again.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #5 of 18 (permalink) Old 09-03-2007, 03:29 AM Thread Starter
Deputydog's Avatar
Re: Turbo Question
Ok sounds good, I'll see if I can adjust it .
post #6 of 18 (permalink) Old 09-03-2007, 03:58 AM
Re: Turbo Question
What is the code you're setting?
gregrob is offline
post #7 of 18 (permalink) Old 09-03-2007, 04:19 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Turbo Question
Check the codes... Could be a HPOP code... Could also be all the Fuel you have...
Joe
CSIPSD is offline
post #8 of 18 (permalink) Old 09-03-2007, 05:29 AM
DarkShadowDiesel's Avatar
Re: Turbo Question
remember it's moving much more area. i don't see over 30 with mine. i see about 27, 28 tops. it sounds like you need to adjust your regulator though
2002 F250
DarkShadowDiesel is offline
post #9 of 18 (permalink) Old 09-03-2007, 02:02 PM Thread Starter
Deputydog's Avatar
Re: Turbo Question
I really hope its not a HPOP code since I have 2 pumps feeding 4 lines into the head.. It must be related to my boost fooler needing to be adjusted.. I will pull the codes and see what it is.
post #10 of 18 (permalink) Old 09-03-2007, 04:50 PM
CSIPSD's Avatar
Re: Turbo Question
Sorry... Missed the dual hpops... Check the codes... Let us know.
Joe
CSIPSD is offline
