Coolant loss from changing t-stat - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-09-2008, 10:45 PM Thread Starter
Burger Flipper
When I replace my T-stat how much coolant is going to come out? Also, do I need to use any rtv or anything when I replace it and the housing?
2000 F250 Lariat SC 4X4, aFe 2 PG7, MBRP 4" SS Duals w/muffler delete, Dipricol gauges, 203* T-stat and billet housing, Dieselsite Coolant filter, 6.0 intercooler...07 Harley Lights, 5K retro-solutions HIDs, ITP pre-pump kit, Harpooned, "The Cure"
J_F250 is offline
post #2 of 4 (permalink) Old 07-09-2008, 10:48 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Re: Coolant loss from changing t-stat
you will probably lose about a gallon or so. New t stat comes with the replacement o-ring. Using some good rtv never hurts to ensure a good seal. Just dont use gobs of it!
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #3 of 4 (permalink) Old 07-10-2008, 03:56 AM
Just put a 5 gal bucket under the drain on the radiator, drain it, then position the bucket under the upper radiator hose/thermo area. My method anyways.. didnt really lose any. I use CAT coolant so, cant afford to loose any
-Chris
chrisreedtn is offline
post #4 of 4 (permalink) Old 07-10-2008, 06:30 PM
aklim's Avatar
It took me almost 2 gallons. 1 of coolant and 1 of water.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
