No fuel pressure help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-09-2008, 10:28 AM Thread Starter
The Fireman
big_stroker's Avatar
Monday night I was driving home and noticed my fuel pressure was dropping from the normal 65 to 55 then it keep going down so i pulled over and it slowly started to go back up but when i took off again it dropped down to like 10 now i have no fuel pressure at all.
I thought maybe it was the pickup tube clogged or cracked but last night i took off the line to the suction side of the pump and could sifion diesel out of the tank that way so its not that. and the fuel pump is running. and i can put my finger on the end of it and it does have some suction 2 it. i just dont have any fuel pressure.
Any ideas? maybe a clogged line from the fuel pump on up to the motor? or maybe the pump just isnt doing its job good enough anymore? I did have a lot of water in my fuel a few weeks ago this have anything to do with it?
big_stroker is offline
post #2 of 11 (permalink) Old 07-09-2008, 10:49 AM
urbanwheeler's Avatar
Re: No fuel pressure help!!
is your pump getting hot? if there is a restriction your pump will get hot. from what it sounds like, your pump's on its way out.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #3 of 11 (permalink) Old 07-09-2008, 11:22 AM Thread Starter
The Fireman
well i let it set for a day and then tried it again and still had no pressure. and i just put the pump on about a year ago
post #4 of 11 (permalink) Old 07-09-2008, 11:34 AM
i have gotten parts that were bad off the shelf, just because its "new" doesnt mean it works. can you put a gauge off the output of the pump?
[SIGPIC][/SIGPIC]
post #5 of 11 (permalink) Old 07-09-2008, 11:41 AM Thread Starter
The Fireman
I have gotten bad parts b4 2... just its been on there for a year no problem dont know why all the sudden it would be bad.
No i dont have a gauge. thought about buying one from napa
http://www.napaonline.com/MasterPage...ressure+Tester
would that work?
post #6 of 11 (permalink) Old 07-09-2008, 01:02 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
That's the way pumps go out generally. What kind of pump is it? Take it off and test it on a bench with 2 buckets or something to see how much it's putting out.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #7 of 11 (permalink) Old 07-09-2008, 01:56 PM Thread Starter
The Fireman
That sounds like a good idea... thats what i will be doing tonight
I'm getting ready to put in the ITP's In Tank / Pre Pump kit and also do a pre lift pump between the tank and the ITP fuel filter should any 7psi pump work? I can get a cheap one from autozone for about $40 and that way there isnt as much stress on the hi pressure fuel pump. Make any since?
post #8 of 11 (permalink) Old 07-09-2008, 02:46 PM
HP Junky
Sounds like a pump issue to me as well. But I'd check your fuel filter and to...
RockinJW is offline
post #9 of 11 (permalink) Old 07-09-2008, 03:36 PM Thread Starter
The Fireman
I know its not fuel filter because my fuel pressure gauge is b4 the fuel goes there they filter
post #10 of 11 (permalink) Old 07-09-2008, 09:37 PM
Village Idiot
southmike's Avatar
is your pump trying to work? meaning getting good power, no relays in between that failed etc..
maybe you have charles' bad luck with pumps and it just died.
southmike is offline
