TN kit measurement? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 07-08-2008, 03:31 PM Thread Starter
Cummins Power
mech2161's Avatar
TN kit measurement?
How high is it from the base to the lower bolt holes?
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #2 of 24 (permalink) Old 07-09-2008, 01:06 AM
What else?
smokyred's Avatar
Re: TN kit measurement?
Kevin, it is 4 and 3/4" from the block surface to the centerline of the lower bolt holes. Also it is 2 and 1/2 inches from the centerline of the rear pedestal mount holes to the flange surface. Would you happen to have the same measurements for a standard H2e mount for comparison?
So the flange mount is taller and slightly forward of an H2e kit mounting flange. It should be close to 2 and 3/4" taller and 1/2" forward.
If you want any other measurements feel free to ask!
Dave
smokyred is offline
post #3 of 24 (permalink) Old 07-09-2008, 01:13 AM Thread Starter
Cummins Power
mech2161's Avatar
No those are what I was looking for. I'll look tomorrow at the H2E mount I have at the shop. Does it come with down pipe?
Kevin
mech2161 is offline
post #4 of 24 (permalink) Old 07-09-2008, 01:27 AM
What else?
smokyred's Avatar
I bought the mount only kit Kevin, it comes with everything in my pictures, so no downpipe.
I think the turbo mounting location is very close to what you have now.
Dave
smokyred is offline
post #5 of 24 (permalink) Old 07-09-2008, 01:31 AM Thread Starter
Cummins Power
mech2161's Avatar
If that mount moves it toward the front of the engine you may have a problem with the down pipe hitting the head. If it's any more than 2 1/2" or 2 3/4" higher you will need a BFH to get it to fit.
Kevin
mech2161 is offline
post #6 of 24 (permalink) Old 07-09-2008, 02:17 AM
What else?
smokyred's Avatar
I just went out and did some quickie measurements on my truck, I don't think I'll have to touch the firewall too much, if any. I do have an OBS though, so I can't say for the Super Duties, my Dad's truck isn't here for me to measure.
I have an idea for the dp, when I had the H2e kit I stuck it on my spare motor and mounted the S4 on one of the top studs and did some measuring and that is very close to where it will sit with the TN mount.
Dave
smokyred is offline
post #7 of 24 (permalink) Old 07-09-2008, 02:23 AM
moore20017.3's Avatar
Are the mounting bolts between turbine and pedistal a PITA to get in? My setup is like that almost exactly except mine is fabricated instead of cast. I used a y off a obs for the up pipes. Anyway, the bolts were a sob to get to. I could not bolt turbo up and still get it in in one piece.
If they found a better way thank god!
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #8 of 24 (permalink) Old 07-09-2008, 02:39 AM
What else?
smokyred's Avatar
On my setup the bottom nuts look easy, lots of room on the bottom to get a hand in there. The top shouldn't be too bad, upper driver's will be the
hardest.
I'm going to try to mount the turbine housing first and then slide the rest of the turbo on together. We shall see how it works.
Dave
smokyred is offline
post #9 of 24 (permalink) Old 07-09-2008, 03:02 PM
HP Junky
That is how my GT42 has to go in. Mount the turbine housing and get the bolts tight. Then slide the center section and compressor on. This t-4 flanged charger is easier to get in and out than the stocker was.
RockinJW is offline
post #10 of 24 (permalink) Old 07-09-2008, 03:12 PM
I built my setup. I learned a lot if I do it again what to improve.
I would have been easier for me to pull cab.
