Fuel Sump - Homemade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 09-02-2007, 01:46 AM Thread Starter
Grumpy Old Bitter Bastard
389SixPack's Avatar
Finished up my st st fuel sumps today. I'll try to get one on in the next week or so. I can drill 2 - 2" dia holes, cut between them, insert backer plate and fasten. I'll let ya know how they work.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #2 of 40 (permalink) Old 09-02-2007, 01:47 AM
Re: Fuel Sump - Homemade
What are these for?
gregrob is offline
post #3 of 40 (permalink) Old 09-02-2007, 01:48 AM Thread Starter
389SixPack's Avatar
Bottom of the fuel tank.
post #4 of 40 (permalink) Old 09-02-2007, 01:50 AM
why
gregrob is offline
post #5 of 40 (permalink) Old 09-02-2007, 01:51 AM
they look great BTW, do you have a cnc?
Looks pro, I might want a set if I figure out why you need them lmao
gregrob is offline
post #6 of 40 (permalink) Old 09-02-2007, 01:53 AM
Haul_n_horses2's Avatar
Are you sure you have enough ports? Those look to be -10 AN? 4 of them? What size fuel pump(s) are you using ie. flow rates? At that flow rate how long will it take to drain that sump?
Haul_n_horses2 is offline
post #7 of 40 (permalink) Old 09-02-2007, 01:58 AM Thread Starter
389SixPack's Avatar
Only going to use two. They are 3/8" NPT. Will run 2-AN#10 to Tee and #12 into Racor fuel/water separator (has 3/4"NPT in it) and that will feed my FASS150/150 to the Aeromotive A1000 marine pump. Other ports will be plugged. Always good to have a drain port!!
post #8 of 40 (permalink) Old 09-02-2007, 02:00 AM
morepower02's Avatar
Originally Posted by gregrob View Post
If I figure out why you need them lmao
Are you for real?
morepower02 is offline
post #9 of 40 (permalink) Old 09-02-2007, 02:09 AM
Yes, I am for real.
Let me try this again.
Why is a fuel sump necessary, or beneficial for a power stroke?
I don't know everything there is to know, who do you guys think I am, Dockboy?
gregrob is offline
post #10 of 40 (permalink) Old 09-02-2007, 02:12 AM
I ran the one from DI on my 02 with the full fuel system. It is a better fuel supply then sucking it out of the top of the tank
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/1244-fuel-sump-homemade.html
Posted By For Type Date
Sump your fuel tank - Parts - Ford Truck Enthusiasts Forums This thread Refback 11-06-2015 08:03 PM
