water injection and turbo surge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-06-2008, 01:27 PM Thread Starter
I am at work with the camper hooked up and getting ready for a 3K road trip starting this afternoon. On the way into work I had a chance to try out the new water injection system. I am running a 3 to 1 mix, water to -20 peak washer fluid. Going up some hills I noticed some minor turbo surge. On one longer hill, for giggles, I turned off the water injection, surging stopped, I turned it right back on and the surging came back. Any idea why it is doing this? I was around 900F to 1000F and 10psi running at 65 in OD.
The only thing I can come up with is with a cooler exhaust temp it is turning the wheel more efficiently causing it to move in to surge zone. (This was not even a SWAG it was only a WAG). I kept watching the best I could and saw no noticable change in boost, only in the EGT when the water was on.
Any suggestions would be great since I am headed for the mountains out west and don't want to surge the turbo to death. o.k. over exaggeration since it is only mild surging, most of the time closer to a stall in flow then a surge back thru the compressor housing, but still damn annoying.
2001 Excursion Preditor tuner, 4" Magna Flow exhaust, AFE II Dry-S, Front spring pack,
add a leaf in the rear, Rear Helwig, and Rancho 9000X all around, HPX, Reg Ret, IAH delete, SP exhaust brake, JW VB, Gauges: Boost, EGT, and tranny temp. Cooling mist EGT/boost, RAS
Waiting to install:
ITP prepump and intank
sheboyganjohn is offline
post #2 of 8 (permalink) Old 07-06-2008, 03:34 PM
Banned
Re: water injection and turbo surge
Run pure water and see if it doesn't stop.
What you're describing is about the complete opposite of what I would expect. You are cooling the intake air charge, making it more dense (takes up less space) requiring that the compressor must pull in more air to maintain the same boost. That's increasing the compressor flow and moving it away from the surge line.
Plus, you should be dropping egt, meaning less energy to drive the turbine wheel which translates into less energy to power the compressor wheel, which should actually lower boost some if anything. Which again, would move you away from the surge line.
The only thing I can figure is that the methanol is adding enough energy that it's driving the turbine wheel harder and pushing the boost up just a hair, and slipping you into surge.
Other than that, I can't see any explanation and I don't have any personal experience with it.
Good Luck.
Charles is offline
post #3 of 8 (permalink) Old 07-06-2008, 03:39 PM Thread Starter
Thank makes sense. As I run her down I will add more water with-out methenol. Of course I have premixed three gallons with washer fluid, I will just have to save those for play time when I am not towing
Waiting to install:
post #4 of 8 (permalink) Old 07-06-2008, 05:21 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Never experanced any surge due to water. Some detonation due to too much meth but no surge... Where are your injectors and what size are they?
Joe
CSIPSD is offline
post #5 of 8 (permalink) Old 07-06-2008, 05:30 PM Thread Starter
I have two 12gph injectors, one is in the spider at the AIH port the other is in the intercooler outlet tube just bofore the IC boot. I am currently injecting over 800F and 6psi of boost with the top of the 2D map at 1400F and 22psi fo boost.
Waiting to install:
post #6 of 8 (permalink) Old 07-06-2008, 05:43 PM
CSIPSD's Avatar
Lower the top of the map to 1250 and 20psi and raise the lower PSI to about 8psi. You might be putting out the fire injecting so low a PSI.
Joe
CSIPSD is offline
post #7 of 8 (permalink) Old 07-06-2008, 07:48 PM
Moderator
Blowby's Avatar
Move the injector at the Y further from the intake and up the lower boost injection to about 10-12 psi.
Edit: I start at 18psi and end (100&#37; duty cycle) at 28psi on my tow truck.
Blowby is offline
post #8 of 8 (permalink) Old 07-07-2008, 05:36 PM
Village Idiot
southmike's Avatar
post back with some findings too please.
I have been looking at water injection for a bit.
one day I will pick joes brain some more if i get close to buying a system.
southmike is offline
