Umm hey! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-06-2008, 05:00 AM Thread Starter
Busy Busy
Marty's Avatar
Umm hey!
I installed my fuel sytem tonight. Started the truck up and it ran. Test it out w/ the big program this week sometime with the fuel pressure gauge. So far w/ the stock tuning it stays at 58.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 15 (permalink) Old 07-06-2008, 06:09 AM
racehauler's Avatar
Re: Umm hey!
What pump did you put in it?
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 15 (permalink) Old 07-06-2008, 05:10 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Umm hey!
RockinJW setup minus the 5/8ths intank tube.
Elkton, Maryland
Marty is offline
post #4 of 15 (permalink) Old 07-06-2008, 11:55 PM
farmboy99's Avatar
Re: Umm hey!
I used the rockinjw setup... the idea works great. and plus you can always limp home on one pump if you had to, I think its a great idea for a pump setup
farmboy99 is offline
post #5 of 15 (permalink) Old 07-06-2008, 11:55 PM
HP Junky
Re: Umm hey!
Let us know how it works with the big tunes in it. Mine pressures never dropped a single psi, with the SHO's or B-codes
RockinJW is offline
post #6 of 15 (permalink) Old 07-07-2008, 12:40 AM Thread Starter
Busy Busy
Marty's Avatar
Re: Umm hey!
Hell I can still whoop azz with a single I was maintaining over 50 psi @ wot...
Sure will. I'm using the stock pickup so we'll see how she goes. since I've welded 3/4" nuts to my bed bolts, taking them out to get access to the tank is no sweat
Elkton, Maryland
Marty is offline
post #7 of 15 (permalink) Old 07-07-2008, 01:02 AM
HP Junky
Re: Umm hey!
you wouldn't have to limp home at all. even with one pump dead the other will supply both heads just like it did from the factory. if one pump fails, it will perform just like it did stock.
I'm running one new pump and the original (134,000 miles) and system works great
RockinJW is offline
post #8 of 15 (permalink) Old 07-07-2008, 01:06 AM
Banned
Send a message via Yahoo to blk99
Re: Umm hey!
so whats this system yall speak highly of???
blk99 is offline
post #9 of 15 (permalink) Old 07-07-2008, 01:34 AM
racehauler's Avatar
Re: Umm hey!
Sounds like 2 stock pumps ran in parallel. One pump feeding each head.
Am I right?
I just put a Walbro in my truck and it's holding 64psi with my B codes, I just hope the pump lasts for more than 30K miles.
Eric
96 F-350 CC Dually
post #10 of 15 (permalink) Old 07-07-2008, 01:44 AM Thread Starter
Busy Busy
Marty's Avatar
Re: Umm hey!
One line, split, into both pumps, join again, up to your fuel bowl/filter/etc whatever your setup is.
I was able to install mine just behind the stocker and only had to drill one hole and it mounted almost flush, but is held in with the 2 other lines so it's not going anywhere.
If someone needs it, I could measure all of the hoses, and put a kit together for the price of parts only so all you have to do is buy another pump....
I seriously went to the hardware store, bought 2 sets of each...
3/8ths Tee fitting w/ 5/16ths holes.
two 5/16 by 1/8" street elbow
three 5/16's by 1/8" barbed fittings
Put them all together with thread tape and used 5/16'ths reinforced rubber hose rated for 60 psi with hose clamps.
I'll draw up a diagram.
Elkton, Maryland
Marty is offline
