crower rods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-06-2008, 12:59 AM Thread Starter
2nd class citizen
1snotrocket's Avatar
crower rods
i have seen crower offers upgraded rod bolts or the standard h-11 and you can get the oiling hole from the big end of the rod to the pin.can any of our sponsors or racer tell me which rod is preffered.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #2 of 6 (permalink) Old 07-06-2008, 01:02 AM
AllYourBaseAreBelongToUs
imelmo's Avatar
Re: crower rods
Talk to David Lott (Powerstroke Racer) at DI. He deals with the Crowers all the time.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #3 of 6 (permalink) Old 07-06-2008, 03:21 AM
Plays with Motors
Machinist's Avatar
Re: crower rods
H-11 rod bolts will be much more than adequate. Rod bolt failures are caused by engine RPM not torque. With these motors spinning less than 5k rpm, the bolts that are in there are over-kill.
Pin oiling is not something to worry about either, the piston squirters do a very good job of keeping that area lubricated and wear is very minimal at rebuild time.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #4 of 6 (permalink) Old 07-06-2008, 07:44 AM
imelmo's Avatar
Re: crower rods
So 1000lbs torque at 3000rpm is the same as 1000lbs of torque at 3800rpm? **baits Charles**
imelmo is offline
post #5 of 6 (permalink) Old 07-06-2008, 08:25 AM
Plays with Motors
Machinist's Avatar
Re: crower rods
I have not seen Charles post anything that I would disagree with
I should explain a little further - in compression(torque applied in power stroke) there is little force exerted on the rod bolts, it's the weight of the piston being stopped at TDC that pulls the big end of the rod into an oval shape(exaggerated) that puts tensile force on the rod bolts - this force is multiplied as rpm increases. Now if you want to bring the beam and shoulders of the rods into the equation the forces act in both directions and is more related to torque applied.
Rod Finite Element Analysis
2011 335i M-Sport
post #6 of 6 (permalink) Old 07-06-2008, 09:38 AM
urbanwheeler's Avatar
Re: crower rods
i like that illustration.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
