What fuel regulator are y'all using? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 07-05-2008, 03:07 PM Thread Starter
cliff-1972's Avatar
At one time I had a Aeromotive reg. and now I am going back to an aftermarket fuel systemso I was wondering the reg. model and # of it y'all are using.
1996 F250 4x4 Reg Cab,98 12V,O-ringed,cam,benched pump,compounds,full billet E4OD/4R100 w/a Precision converter
cliff-1972 is offline
post #2 of 22 (permalink) Old 07-05-2008, 03:26 PM
Member
vapstroke's Avatar
Re: What fuel regulator are y'all using?
ITP diesel's reg return system uses a Aeromotive regulator and is a really nice setup.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #3 of 22 (permalink) Old 07-05-2008, 06:29 PM
OEM Moderator
Tom S's Avatar
I also use the regulator that Dennis uses in his kits.
Tom
Tom S is offline
post #4 of 22 (permalink) Old 07-05-2008, 07:38 PM
DarkShadowDiesel's Avatar
I believe this is what they are referring to: link
I use this one, which some of the kits have used: link
2002 F250
DarkShadowDiesel is offline
post #5 of 22 (permalink) Old 07-05-2008, 07:46 PM
How about using this one. Its the same as the 13101 but rated for Gas/Alcohol/Diesel as opposed to just Gas/Alcohol.
2002 F250SD SC LB 4x4, AFE Stage 2 PG7, MBRP T304 Cool Duals, BD Exhaust Brake, WW, ATS Housing, FTVB, TM Wastegate Controller, Brite Box, CCV Mod, Coolant Filter, 9 Isspro Performax gauges.
To-Do: Air-Lift Air Bags install
90ranajo is offline
post #6 of 22 (permalink) Old 07-05-2008, 10:40 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
haha i guess you know what i got
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #7 of 22 (permalink) Old 07-06-2008, 12:53 PM
NEVRNF's Avatar
This is what i am going to run when my SX one dies. 2 year warranty for ANY fuel used in it.
Fuelab
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #8 of 22 (permalink) Old 07-06-2008, 02:09 PM
Don't EFN worry about it
Aljay's Avatar
who da fook carries them and what do they run I need one for my truck ..........
Tuned by T Wildman
Aljay is offline
post #9 of 22 (permalink) Old 07-06-2008, 06:56 PM Thread Starter
cliff-1972's Avatar
Yes,Jason I know which one you gotThanks,everyone for the input.This is the last item I need to get for my fuel system.NOW just got to figure if I want to do the full blown system(new pick up and return) or the simple way by keeps the stock sending unit pick-up and returns.I think a Bronco tank would be great,but what do I do with the front fill door.
post #10 of 22 (permalink) Old 07-06-2008, 07:00 PM
Dzl Jim has done the bronco thing and has a write up on his site... www.dzljim.com
2002 F250
