Bad turbo seal????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-01-2007, 06:14 PM Thread Starter
Bad turbo seal?????
Hi gang,
Friend of mine picked up a Garrett BB turbo for a good price. The turbo is new, never installed, however it's 3 years old. I was kinda worried about the seals, so I put some oil in the feed/drain hole. After about 45 minutes sitting on the bench the oil migrated to the exhaust/turbine side of the turbo while the intake/compressor side seems to be dry.
Do we have a seal issue, or is this unit ok for install?
Thanks,
horses2 is offline
post #2 of 4 (permalink) Old 09-01-2007, 09:47 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Bad turbo seal?????
No, thats normal for the GTP-38r... I think they design it for oil leaks to keep the housings from rusting...
Joe
CSIPSD is offline
post #3 of 4 (permalink) Old 09-01-2007, 11:21 PM
Originally Posted by horses2 View Post
Hi gang,
Thanks,
Without a place for the oil to drain to it will leak. The oil will drain where ever there is least resistance. The best thing to do is clean turbo so there is no oil on it and try it on the truck. Then you will know if there is a problem.
FullBoost is offline
post #4 of 4 (permalink) Old 09-02-2007, 08:07 AM
No Joe, it is only normal on your truck!!!
Diezel Dawg is offline
