Is this a normal amount of blow by? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 07-03-2008, 05:55 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I am just asking, please dont start any crap...
http://alldieselmotorsports.vidiac.c...8501654e66.htm
http://alldieselmotorsports.vidiac.c...85016381b4.htm
Joe
CSIPSD is offline
post #2 of 31 (permalink) Old 07-03-2008, 06:08 PM
Hoosier daddy!
Ramblin'_Man's Avatar
Re: Is this a normal amount of blow by?
You have many more mods than I do, so I can't account for that but it appears to be a lot more blow by than I have. I don't even get a slight haze out of my filler neck at idle. Easiest way to check for excessive blow by(pressure) is to unscrew the filler neck cap and set it on the opening. If there is enough pressure to pop the cap off, it's excessive. That's just a general rule of thumb though and not a "proper" diagnosis. Hope that helps some.
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #3 of 31 (permalink) Old 07-03-2008, 06:10 PM Thread Starter
CSIPSD's Avatar
Take into account this motor has 25k on it...
Joe
CSIPSD is offline
post #4 of 31 (permalink) Old 07-03-2008, 06:18 PM
Banned
So I shouldn't say anything about the blue wire loom then? Or the "crack rock" filming technique?
Charles is offline
post #5 of 31 (permalink) Old 07-03-2008, 06:24 PM Thread Starter
CSIPSD's Avatar
Its the only color Fred Meyer had... I'll change it to black...
Cant help on the filming, I was trying to get a shot of the CCV out the tube as well but you couldnt see it... I have a CCV vent on both the drivers and passangers side right now...
Joe
CSIPSD is offline
post #6 of 31 (permalink) Old 07-03-2008, 06:26 PM
Banned
I didn't see anything that was just hanus. Before I rebuilt the engine it would roll the smoke all the way up past the hood sitting at a red light.
Still ran smooth.
Charles is offline
post #7 of 31 (permalink) Old 07-03-2008, 06:29 PM
All done now
Arisley's Avatar
Try what Ramblin says, except set the cap upside down on the fill tube. Only 25K on it. Rings may not be seated yet.
Arisley is offline
post #8 of 31 (permalink) Old 07-03-2008, 06:30 PM Thread Starter
CSIPSD's Avatar
Still ran smooth.
Ok... But did your motor have 25,000 miles on it, thats where I am concerned, from day one it has had what I would say excessive CCV?
Joe
CSIPSD is offline
post #9 of 31 (permalink) Old 07-03-2008, 06:33 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
HAHA, you need a boost gauge for your valve covers...
Just kidding!
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #10 of 31 (permalink) Old 07-03-2008, 06:44 PM
<<<<< Next Generation
boggerr's Avatar
Try what Ramblin said. Mine did smoke like that but I had 120,000 on the clock.
Maybe it's just the video but Is that oil milky looking on that cap????
You don't have a gauge to measure blow by yet
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
