optimal air temp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 07-03-2008, 02:12 PM Thread Starter
optimal air temp
I've been reading the "optimal fuel temp" thread and was wondering is there an optimal air temp for the air going into the engine? If so is that temp engine load sensitive? My thinking was since a diesel gets better MPGs during summer vs winter that there must be the perfect inlet temp for a diesel unless the MPG difference is all in the winter blend.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 2 (permalink) Old 07-03-2008, 04:05 PM
racehauler's Avatar
Re: optimal air temp
As far as intake air temp goes the cooler the better. That is why we have a charge air cooler (intercooler) to cool the air back down after compressing it via the turbocharger. Cooler air is more dense and provides the same advanges that pressurizing (in our case turbocharging) the intake air yeilds. I know that everyone here hates Banks but they do have a good explanation of this here - http://bankspower.com/Tech_bigdensity.cfm
The mpg during the winter has to do with the fuel and the dense air makes more aero drag on the truck.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
