Dieselsite HPOP reservoir adapter - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 185 (permalink) Old 07-03-2008, 01:55 AM Thread Starter
OEM Moderator
Tom S's Avatar
http://www.dieselsite.com/index.asp?...rodID=868&HS=1
I thought this looked interesting so to sound like Danny discuss.
Tom S is offline
post #2 of 185 (permalink) Old 07-03-2008, 02:14 AM
RDRCM
CooterBrown's Avatar
Re: Dieselsite HPOP reservoir adapter
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #3 of 185 (permalink) Old 07-03-2008, 02:44 AM
Village Idiot
southmike's Avatar
it is an adapter for early 99 type hpop's. newer trucks have the screen.
also worth a note... if you mix gaskets from old to new you can crack the housing
southmike is offline
post #4 of 185 (permalink) Old 07-03-2008, 03:04 AM Thread Starter
OEM Moderator
Tom S's Avatar
There is some more interesting reading if you go to dieselsite page.
Tom S is offline
post #5 of 185 (permalink) Old 07-03-2008, 03:13 AM
HP Junky
The rear pump cavitates
RockinJW is offline
post #6 of 185 (permalink) Old 07-03-2008, 03:21 AM
Starting Over
kainers's Avatar
I think it would work pretty good and could be used in an addition to someones dual pump set up.I would have to ask the Dual pump builder if it would be ok with there system though.
kainers is offline
post #7 of 185 (permalink) Old 07-03-2008, 03:24 AM
2nd class citizen
1snotrocket's Avatar
the only advantage i see would be extra oil for the hpop's due to the spacer.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #8 of 185 (permalink) Old 07-03-2008, 03:49 AM
HRT Performance
HotRodTractor's Avatar
Ports are a good idea, interesting thoughts on the rear pump being starved.... I talked to Bob a little bit at TS about this adapter and found it interesting then too.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #9 of 185 (permalink) Old 07-03-2008, 04:01 AM
ARMY bound
That's some good reading!
bbbxcursion is offline
post #10 of 185 (permalink) Old 07-03-2008, 04:07 AM
HP Junky
Whats the whole thought process behind the rear pump starving? How is this possible? I'm confused? Also, why does the adapter need a 2nd IPR port?
RockinJW is offline
Closed Thread
